Go Back   HondaCivicForum.com > Your Ride > Suspension, Brakes, Tires & Wheels
Reply
Old 03-20-2006, 08:21 AM
00canSI 00canSI is offline
Default good handling without lowering
I want to lower my civic, but the underground parking ramp at my apt is so steep I scrap the underside at the bottom even if I'm on a diagonal. So my lowering is kind of out of the question right now, but would it still be beneficial for me to upgrade my shocks, and put upper and lower strut bars and upper and lower tie bars. Also, do you really need upper and lower or will it make a huge difference to just have upper, or just have lower?
thanks, and any other ideas would be appreciated.
Sponsored Links
Old 03-20-2006, 08:29 AM
mentaldis0rder mentaldis0rder is offline
Send a message via AIM to mentaldis0rder
Default RE: good handling without lowering
sway bars below.. and strut bars for top.. also u can get adjustable coilovers and keep stock ride with better quality of spring.. and lower them later
__________________
1996 CX Hatch.. Click below for mods!!
Work In Progress
Old 03-20-2006, 10:00 AM
ef4life ef4life is offline
polyurethane bushings made the biggest difference i ever felf on my car, your car is a lot newer i am assuming so your bushing won't be as worn as mine were
__________________
Old 03-20-2006, 02:34 PM
Kappa22 Kappa22 is offline
Strut and sway bars are a must. Also, you can add some relatively inexpensive dampers to your car with the OE springs to tighten it up. Tokico HP's top the list.
__________________
Your Forum Turbo Groupie...
Also your official Forum EF and GTR Brain-Trust
Old 03-20-2006, 05:20 PM
Nail I3unny Nail I3unny is offline
Send a message via AIM to Nail I3unny
H&R OE springs keep you at about stock height but theyre stiffer than stock springs.
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
