Go Back   HondaCivicForum.com > Your Ride > Header, Intake, & Exhaust
Reply
Old 03-22-2006, 08:42 PM
Spark Spark is offline
Send a message via AIM to Spark
Default Tell me how to install headers!!!
well i just picked up some megan headers today...and i know they are pretty much bolt on but i just wanted to make sure. cause some guy was mentioning something about a O2 something or other. and i don't want to mess it up. or....and i was wondering if they were legal or not....i'm going to put them on regardless.
__________________
Sponsored Links
Old 03-22-2006, 08:48 PM
Pete Pete is offline
Send a message via Yahoo to Pete
Default RE: Tell me how to install headers!!!
Take the stock exhaust manifold off, remove the 02 sensor. Put the 02 sensor in the new exhaust manifold, bolt it back on but use a torque wrench. Tighten it to honda specs. Use the old gasket, dont get a new one.
__________________
1994 Civic coupe. B18C, A few Bolt Ons.
Old 03-22-2006, 09:04 PM
and that's it right? cool deal.....hopefully i'll have time to do it tonight. thanks a lot.
__________________
Old 03-23-2006, 10:38 AM
rit14623 rit14623 is offline
I've done exhaust replacements but never a header. Is there a certain order you are to torque down the bolts?
Old 03-23-2006, 10:54 AM
polo708 polo708 is offline
Send a message via AIM to polo708
start from the middle and work your way out... that will get you the best seal. The o2 sensor should "clip in" some where close to teh block.
install:
1. Just find the o2 sensor which is sticking out of the header (exhaust maniflod) and follow the wires to where it ends. Disconnect that from the clip.
2. Go under the car and disconnect the midpipe from the header
3. Disconnect the header from the block.
4. Remove the o2 sensor from the header.
5. Install o2 sensor in new header
6. Connect the new header to the block (tighten from inside out)
7. Connect midpipe to header
8. Reconnect o2 sensor harness back to the car.
is it legal? Probably not, unless its a DC Sports header. They always seem to have CARB legal headers. Most of your off brand and ebay headers are not CARB approved.
__________________
-brian
Old 03-23-2006, 01:15 PM
itsmeek itsmeek is offline
what pole said..it's very straightforward bro, just get in there and you will realize it's not all that complicated.
__________________
2002 corvette z06
former car:
2002 rsx-s turbo
Old 03-23-2006, 04:18 PM
Nail I3unny Nail I3unny is offline
Send a message via AIM to Nail I3unny
i was gunna say wouldnt it e easier to take out and re-install the o2 sensor first?
Old 03-23-2006, 10:46 PM
have a problem.....one of the bolts the connect the header to the midpipe is stipped!!! what is the best way to get this out?!? cause i've come to a stand still with this.
__________________
Old 03-23-2006, 10:56 PM
id have to say the best way to get it out is to cut it...but im not sure.
Old 03-23-2006, 11:04 PM
yea that's what i was thinking....if no one else has any other way i'm just going to do that.
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
