Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
Replacing Wheel Studs by Street Sniper
  Printable Version
Honda Civic Forum >> General Automotive >> DIY - Do It Yourself >> Drivetrain DIYs >> Replacing Wheel Studs by Street Sniper Page: [1]
Login
Message << Older Topic   Newer Topic >>
Replacing Wheel Studs by Street Sniper - 3/25/2006 7:58:13 PM
mxs
Status: offline
mxs's photo gallery
Thanks to Street Sniper for this DIY!
The wheel studs come out just like a bolt. Unfortunately without taking the whole sum'bitch apart you have to grind the stud and the hub down so that you can slide them in there. It's really not that big of a deal.
Take the wheel off and get behind the caliper. Take these bolts off.
Take the disc off.
You can see here where it is grinded (ground?) down so that you can slide it past. Turn the rotor so that the bad wheel stud is here and beat it out.
Wheel stud before. These are like 99 cents from your local parts store, maybe $1.99.
Grind it down pretty good to where it is almost flat on one side. Hold it with something 'cause it gets a little warm.
Wheel stud after.
Now wiggle it in, grind to grind.
Now you need to get some sort of spacer to pull the stud into place. I used a nut here that is bigger than the lug. Put it on the stud and then tighten the lug down on it and it will pull the stud in tight where it needs to be.
Bam, and there you go. I doubt this is how Hayne's will tell you to do it, but this is the real world, son.
_____________________________
Driving takes 3 abilities: Accelerating+braking+turning. More power only helps acceleration. Lower weight helps all 3.
DON'T EMAIL ME W/ TECH QUESTIONS, I WILL IGNORE YOU.
Post #: 1
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Honda Civic >> General Automotive >> DIY - Do It Yourself >> Drivetrain DIYs
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414244
remmy11161
fiirkan10515
mill$civic8471
marty8273
mxs8006
fliphkd7207714
nail i3unny7705
sacicons7675
addiction2ba7375
New Vendors
K&N Engineering, Inc.
