Go Back   HondaCivicForum.com > Your Ride > Engine & Internal
Reply
Old 03-25-2006, 11:46 PM
greencivic greencivic is offline
Default wrong engine
i've got a 1993 honda civic ex the under the hood label say's it should have a d16z6 but ever since i've bought it came with a d15zi i believe is a non v-tec engine from a vx cause it say's it the valve cover it runs real good the only problem that when i took it for a california emmissions test it failed because to many hydrocarbons and unburned gas at 2500rpm's at idle is fine .i just wanted to know if the having a non-vtec engine is affecting it .i have a d-15 that is vtec can someone tell me if it's could be compadible with my car thank's for you're time .before i forget i've replaced the idle air control valve ,intake air temperature valve,o2 sensor and caalitic converter.
Sponsored Links
Old 03-26-2006, 03:42 AM
Marty's Avatar
Marty Marty is offline
Send a message via AIM to Marty
Default RE: wrong engine
are you getting a check engine light and if so are you running the 92-95 p28 sohc vtec ecu. If that is what is running your car you will emmit to many hydrocarbons and unburnt gas at around 2500rpm being the d15z1 is running on 8 valves up untill then and the ecy is feeding fuel for a 12 valve setup.
__________________
1989 Mustang LX Notch 5.0 5 speed SSP(Utah State Police car) 1 of 776 Made Nation Wide
Old 03-26-2006, 09:16 PM
97civicturbo 97civicturbo is offline
how did you make sense of any of that lol?
__________________
97 civic ex coupe-D16z6 head-P&P-Skunk valve springs, retainers etc.-Skunk 2 Intake manifold w/Aem rail-Skunk2 Stage II cam-ARP Headstuds D16y8 block-Wisecvo pistons 8:6:1-Eagle H-Beam Rods-Blockgaurd-Stage IV XTD Racing Clutch-Emanage-T3/T4 .63 turbo
Old 03-26-2006, 11:17 PM
would my d15b v-tec work in my car
Old 03-26-2006, 11:40 PM
Marty's Avatar
What d15 vtec do you have?
If it is a JDM D15B then yes it will work fine
__________________
Old 03-26-2006, 11:55 PM
yes it's a jdm thank's for the help i will swap them an let you know how it goes in the test after thank's again .
Old 03-27-2006, 12:31 AM
Marty's Avatar
No problem at all man, I responded to your email and if you have any questions at all please stay in contact with me as i am pretty sure I can help
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
