Go Back   HondaCivicForum.com > Your Ride > Engine & Internal
Reply
Old 03-26-2006, 08:26 AM
POIZN POIZN is offline
Default 5th Gear
Hi, i drive a D16Y9/D16Y7. I dont know about other honda's but my 5th is like a donkey. I can hit 200kph in 4th gear but when i change to 5th the power and torque just dies out. The car slows down to around 150kph. Its really frustrating. Anybody have to same prob or know a solution?
__________________
96 Civic EK 160i D16Y9
Simota CAI
Powerflow Exhaust
Sponsored Links
Old 03-26-2006, 11:08 AM
mentaldis0rder mentaldis0rder is offline
Send a message via AIM to mentaldis0rder
Default RE: 5th Gear
5th gear is just a gas saver gear..only reason to shift into 5th is for cruisin on highway
__________________
1996 CX Hatch.. Click below for mods!!
Work In Progress
Old 03-26-2006, 12:14 PM
Kedawei Kedawei is offline
Solution: make more power out of that engine, or swap in another.
Old 03-26-2006, 01:18 PM
riceburner700's Avatar
riceburner700 riceburner700 is offline
Send a message via AIM to riceburner700
the motor cant push that long of a gear ratio so it will intern slow the motor down so it doesnt work as hard. That is how my 5th gear was until i put some motor mods in and put in the turbo kit. Just start putting mods onto the engine and you will see a difference top end
__________________
cylinder head guru!
Non Vtec power
Old 03-26-2006, 01:24 PM
Street Sniper Street Sniper is offline
I don't know why it would slow down, but like mental said, it's just a cruising gear. It's really tall and gives a huge mechanical advantage so that the motor doesn't have to spin so fast to stay at highway speeds. If it bothers you that much, swap in an Ex/Si tranny.
__________________
Tuned by G-Tech... Powered by YooHoo.
Quote:
...there's more than one way to skin the horsepower cat.
Old 03-27-2006, 04:52 PM
Compared to every other car, i think it should at least keep its speed on a flat road. Gonna shop around for the trans and see what happens. Thanks guys
__________________
Simota CAI
Powerflow Exhaust
Old 03-27-2006, 05:25 PM
if ur saying that in 5th it actually starts to slow down and not just have no real acceleration then ur clutch may be going.. check and make sure ur not slipping out of gear.. i had this problem with an old dodge shadow.. up hills mainly.. it would keep popping out of gear in 5th.. ended up being clutch going out
__________________
Work In Progress
Old 03-27-2006, 05:45 PM
No no. It doesnt pop out of gear. Actually recently i just replaced the gearbox seals, shaft and bearing. The oil leaked onto my clutch and i thought i was worn out but my mech sez it was the seals and the bearings and shaft wasnt too good either, so i asked him to sort it out. Had to put in a new clutch as well. All these parts are brand new (4 wks old now). Its been like this since i got the car. Maybe it was a bad buy
__________________
Simota CAI
Powerflow Exhaust
Old 03-28-2006, 06:16 AM
Yeah sorry.. if it was mine i know what my next step would be.. buying an OE rebuilt LSD tranny and slapping it in there..
__________________
Work In Progress
Old 09-07-2007, 02:40 PM
Koireland Koireland is offline
Um why swap in an Si tranny my Si does the same thing and I have cold air intake and a 5Zigen catback exhaust. 200ish in 4th, but shift into 5th and it just sit's there no up no down.
__________________
A.Ireland - 1993 Civic Si Hatch
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
