Go Back   HondaCivicForum.com > Your Ride > Nitrous, Super Chargers, & Turbos
Reply
Old 03-28-2006, 09:32 PM
D16z6 D16z6 is offline
Default Turbo on Road Trip
So is it safe and reliable to run boost and drive the car on a long distant road trip? I dont want anything to melt, overheat, catch on fire or breakdown.
__________________
A
Sponsored Links
Old 03-28-2006, 09:39 PM
riceburner700's Avatar
riceburner700 riceburner700 is offline
Send a message via AIM to riceburner700
Default RE: Turbo on Road Trip
shouldnt, i know that when im cruising down the highway at 75mph im ready 1psi of boost on my t3 and my gas gauge goes way up because the motor wont have to work as hard to get the power, it makes the turbo add its little kick in. Now yes if you are like shifting like a bat out of hell running down the highway for long distances at 5k then yes you are probably gonna start to tear some stuff up.
No problem with a turbo on long trips, just watch your engine temp gauge and it should be all good
__________________
cylinder head guru!
Non Vtec power
Old 03-28-2006, 10:46 PM
aryiman98civic aryiman98civic is offline
Send a message via AIM to aryiman98civic
so when you go on long trips just put the boost at 1 psi and you will be fine?
__________________
spooling on the b16!
Old 03-28-2006, 10:49 PM
Pete Pete is offline
Send a message via Yahoo to Pete
You wont understand it until uve boosted a motor. When you are crusing at highway speeds you wont be boosting. I drive to south jersey frequently, and Ill drive for 1.5 hrs at 75 mph and my boost/vac gauge will be reading 10 inches of vac.....no boost....but when u touch the throttle the boost is right there.....so when ur crusing u shouldnt really even be in boost.
__________________
1994 Civic coupe. B18C, A few Bolt Ons.
Old 03-28-2006, 10:56 PM
fast93civic fast93civic is offline
Send a message via AIM to fast93civic Send a message via Yahoo to fast93civic
You gotta remember though, yours is an auto. On a 5 speed, you're going to be spinning a bit more RPM's, so more prone to boost.
__________________
Apexi AX53 turbo, intercooled-stock PSI
Vortech FMU
Tsudo exhuast
MSD Super Conductor wires
Holley 68mm TB
Skunk2 Manifold
Walbro-255
AEM fuel rail, FPR
Dropzone coil/struts
Sumitomo HTRZII's on 16s
Old 03-29-2006, 12:22 AM
it also depends on how much your foot is into the throttle to, but that is also a good point pete, forgot to mention that
__________________
cylinder head guru!
Non Vtec power
Old 03-29-2006, 12:24 AM
but on the highway your gas mileage will go UP because of the forced air going into the cylinders which is greater than the enge was stock
__________________
cylinder head guru!
Non Vtec power
Old 03-29-2006, 12:25 AM
Quote:
ORIGINAL: fast93civic
ACtually, it should be less. Consider that a 5 speed has an "extra" gear than an auto......so while crusing at higer speeds 5 speeds can shift into fifth........which should result in lower RPMS, and higher inches of vac.
__________________
Old 03-29-2006, 12:27 AM
Kappa22 Kappa22 is offline
Cruising = 0 or negative boost.
__________________
Your Forum Turbo Groupie...
Also your official Forum EF and GTR Brain-Trust
Old 03-29-2006, 12:30 AM
Yea........anyone who drives a boosted whip knows this.
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
