Go Back   HondaCivicForum.com > Your Ride > Audio/Visual Electronics
Reply
Old 04-01-2006, 09:32 PM
zapman98 zapman98 is offline
Default 52mm gauges
Hey everyone,
I'm looking to install some gauges in my 98 AT Civic DX. What gauge pod would you guys recommend? I've seen A-Piller, Dash, and ones in the cluster.
As for the types of gauges, which are the most useful? I don't have a turbo or SC so I really don't need a boost gauge. I would really like to put in a 52mm tach and maybe 1 other gauge like air temp. Are some gauges easier to wire than others? Any DIY's in this area?
All help is appreciated
Sponsored Links
Old 04-03-2006, 05:14 PM
mill$civic mill$civic is offline
Default RE: 52mm gauges
its all about preferance for were you want them mounted..my preferance is the A piller, you want a tach and and it all depends on what you want to moniter most..i have a volt gauge to monter if i have my car off and my system on, and oil presser because you can never go wrong with that..like i sead it all depends, and for wiring, yes all gauges are different to wire..even by brands, most things are the same tho...i dont think theres any DIY, but tacks are easy..volt meter is easy..umm go to autometer.com and they have a instructional page on how to wire up all there different gauges, it will give you a idea of how to wire them up and all the different gauges you can get
__________________
Member since Feb 2005
Old 04-03-2006, 05:58 PM
k thanks. Does the tach just plug into the tach harness behind the cluster?
Old 04-03-2006, 07:24 PM
Berzerker Berzerker is offline
I run mine from the tach test port under the hood. its right in front of the hood hinge on the driver side.
Berz out.
Old 04-03-2006, 08:19 PM
riceburner700 riceburner700 is offline
Send a message via AIM to riceburner700
i would do
volts
oil pressure and
egt
__________________
non-vtec ALL THE WAY
cylinder head guru!
Old 04-03-2006, 11:43 PM
bakinwagin bakinwagin is offline
Location: transplanted to the land of the Wild & Wonderful
Send a message via AIM to bakinwagin
Quote:
ORIGINAL: Berzerker
Berz out.
I second this move! I had to tie-in a tach monitor wire for my remote start and after it was all said and done...going through the firewall and tappin in to the above wire was easier than finding the right wire under the dash (which I obviously never found!!!)
__________________
"P"
Life is GOOD!
Cheaper to fix or Easier to replace---Pick your poison
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
