Go Back   HondaCivicForum.com > Your Ride > Engine & Internal
Reply
Old 04-09-2006, 10:29 PM
xthe1nonlyx xthe1nonlyx is offline
Default oil pan
i have a 98 honda civic ex vtec ...im going to be replacing my oil pan in a few days...i was just wondering what the proper procedure on replacing the oil pan and gasket was.
Sponsored Links
Old 04-09-2006, 11:55 PM
riceburner700 riceburner700 is offline
Send a message via AIM to riceburner700
Default RE: oil pan
just let the oil drain out for like an hour so you get as much out of it as posible so you have less of a mess.... you will have to probably have to remove the flywheel bottom cover to get to the 2 nuts behind it in order to remove the oil pan.... Get a new gasket or else you will be sry, also right were the oil pan dips down on the oposite sides of each other put some liquid gasket right on the bends were they start to turn downwards or else that is were the oil pan is gonna leak first... and then reinstall the oil pan and tighten everything evenly and snuggly and you should be golden..
__________________
non-vtec ALL THE WAY
cylinder head guru!
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
