I've been trying to find a shop to get a quote on rebuilding a GSR engine, but i've had no luck. I've emailed a couple shops already and nobody has replied as of yet. Does anyone know any shops in the area that will do the work?
The thing is that i wanna do most of the work on my own, but there is some stuff that i can't do and other stuff that is too complicated for me to do. I can't bore/hone the block and isntall sleeves. I don't know how to blueprint a block. I don't want to install the pistons/rods/crankshaft/bearings. I know that there is AMS (but they do DSM work mostly) and there is SpeedSix motorsports that does Honda work and another shop i can't remember. I think that if i was to call them i would get a better respones, but since i'm not that serious about getting the work done i don't want to do it. What do you need done?
I need to find someone who can wire a Profec II Electronic Boost Controller and help me swap a ZC into my EG, which i'm positive i can do the swap myself but the wiring is where i will need help, i did the swap into my old SiR-T and now i'm taking that motor and putting into my EG
__________________
Quote:
ORIGINAL: Forty04
Theres really only two seasons here in Michigan, winter, and construction.
I wanna learn how to do engine swaps so i can swap a GSR into an EG couple when i get one. How hard can it be to wire the boost controller? Does it come with instructions?
Seriously? You think i can get the whole engine, trans, harness, ECU for 500 or less? If you get a tip on one, ill be all over it like a stink on a monkey.
i would be happy to find places around me that do anything.. all of the tuner shops are closing.. i know of Jeff evans having a shop but dunno if he does or has somebody that does the engine rebuild part.. not just tuning..but even that is hours away from me.. which means alot of cash for towing the car to and from..
__________________
1996 CX Hatch.. Click below for mods!!
