Go Back   HondaCivicForum.com > Your Ride > Audio/Visual Electronics
Reply
Old 04-30-2006, 07:43 PM
Josh Josh is offline
Default 250/400
what would be louder with a 300watt rms amp 2 250watt rms 12" memphis pr's
or 2 12" 400watt rms precision audio subs with a 300watt rms amp
__________________
Josh
Sponsored Links
Old 04-30-2006, 09:33 PM
mill$civic mill$civic is offline
Default RE: 250/400
well you would probably have to look at the tasts on both subs and see what the differences are, but the 400 rms would be louder
__________________
Member since Feb 2005
Old 04-30-2006, 10:56 PM
Default RE: 250/400
the 400watt subs would be louder with only a 150watt each?
__________________
Josh
Old 05-03-2006, 10:26 AM
TeamExodusPres TeamExodusPres is offline
Default RE: 250/400
Theres no replacement for just getting plain old good quality equipment. So for that fact id go with the memphis. I've heard a couple sets of them and they sound nice. But if your just changing the brand of subs, and running them on the same amp, theres not going to be too huge of a difference. The company should have a rating of how much SPL is created at 1 watt for each though if you really want to get specific. Most companies have that. The rms a sub can handle has no difference on how loud they play, just how loud they CAN play. The amps what you have to worry about
__________________
D16Z6 Bored to 75.5mm
JE Forged Pistons
Eagle H Beam Rods
Crower Full Top End
Full-Race Turbo Kit
343 WHP in a Del Sol
www.myspace.com/teamexodus
www.gothespeedofsound.
Old 05-03-2006, 12:49 PM
Default RE: 250/400
thea both heav a 88db spl
__________________
Josh
Old 05-03-2006, 03:00 PM
Default RE: 250/400
theyll both be just as loud then on the same amp.
__________________
JE Forged Pistons
Eagle H Beam Rods
Crower Full Top End
Full-Race Turbo Kit
Old 05-03-2006, 06:21 PM
Default RE: 250/400
? what so if u had a 300rms sub with 93db sensitivity it would hit a higher db then
a 300rms sub with a 88db sensitivity?
__________________
Josh
Old 05-03-2006, 06:49 PM
Default RE: 250/400
Yes sir, but if your getting really indepth into your system and want something specifically designed for your car, check the frequency that the box should be made to too, and make sure that its somethin in the 40s or 50 Hz range (which most now a days are) since thats where alot of music plays, but as far as just throwin one in a prefab box, the 93 DB one is going to technically be louder
__________________
JE Forged Pistons
Eagle H Beam Rods
Crower Full Top End
Full-Race Turbo Kit
Old 05-03-2006, 09:05 PM
bobbytonic bobbytonic is offline
Default RE: 250/400
Quote:
ORIGINAL: TeamExodusPres
[no]
Sensitvity means nothing without taking into consideration the T/S parameters of the subwoofer.
If you build a box in the 40/50 hz range you are building a wonderful one note wonder fart machine. Yes I know Best buy pre-fabs are tuned to this and frankly my previous statement applies.
To answer the original question get subwoofer that will better fit your install. If you are putting them in a sealed box, then get the subwoofer that plays best in a sealed box. Or imo, get a single subwoofer that will play the full 300 watts, will probably sounds better then two subs receiving half their RMS
__________________
Old 05-03-2006, 09:52 PM
Default RE: 250/400
what is t/s
__________________
Josh
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
