Go Back   HondaCivicForum.com > Your Ride > Audio/Visual Electronics
Reply
Old 05-01-2006, 02:18 PM
Remmy Remmy is offline
Administrator
Default My trunk instal
Its pretty sweet. I wanted to put the sub below the floor and have a 12" grill flush mounted with the carpet but I didnt have enough depth. But I went to plan b which is ok I guess. The sub is about 2 times more effective and can handle a hell of a lot more power.
The Dayton High Output Subwoofer. The best by far $100 I have ever spent.
__________________
Sponsored Links
Old 05-01-2006, 02:22 PM
Administrator
Default RE: My trunk instal
In case you were wondering, I used a lot of screws because this damn sub has killed two pre fab boxes in the past. Ive never had that problem before with a sub destroying a box. I used extra screws to insure that it will take the immense pressure this high excursion sub will make.
Here are the specs: Specifications: *Power handling: 600 watts RMS/1000 watts max *VCdia: 2-1/2" *Le: 1.75 mH *Impedance: 4 ohms *Re: 3.4 ohms *Frequency range: 24 - 600 Hz *Fs: 24 Hz *SPL: 87 dB 2.83 V/1m *Vas: 1.20 cu. ft. *Qms: 4.20 *Qes: .36 *Qts: .33 *Xmax: 12mm *Dimensions: A: 10-1/2", B: 9-1/4", C: 5".
Here is where you can get one: http://www.partsexpress.com/pe/showd...number=295-462
Its got the Remmy approval stamp [sm=smiley20.gif] and when it comes to car audio, im a picky son of a bitch.
__________________
Old 05-01-2006, 03:01 PM
psychocivic psychocivic is offline
Send a message via AIM to psychocivic
not bad!! me likey. how long did that take you?
__________________
Old 05-01-2006, 03:17 PM
Administrator
4 hours
__________________
Old 05-01-2006, 03:27 PM
not bad. i'm planning on doing something like that soon myself. but with plexiglass on top or do the whole trunk in fiberglass. i know it will be a pain but think of how it will look when done.
are you going to put anything in the rest of the open space?
__________________
Old 05-01-2006, 03:41 PM
Administrator
No. Its going to stay like that. I wanted to do the mesh grill thing so I would have to worry about the open sub but ill live. I just need to find one of those obnoxious kicker grills now.
__________________
Old 05-01-2006, 04:09 PM
Administrator
Here is a video showing off the sub at work. That distortion is because the camera cant handle the bass it was pumping out so you've got a pretty good idea how good it can be.
__________________
Old 05-01-2006, 04:20 PM
mxs's Avatar
mxs mxs is offline
Administrator
Needs more cowbell.
Nice work Remmy. And the plate frame still looks good... did you know you're the ONLY person who has one? (hint hint, ya slackers)
__________________
Driving takes three abilities: Accelerating, braking, and turning. More power only helps acceleration. Lower weight helps all three.
PLEASE DON'T PM ME WITH TECH QUESTIONS, I WILL IGNORE YOU.
Old 05-01-2006, 04:27 PM
Administrator
Cowbell?
And in regards to the other statement... thats pathetic!!!!
__________________
Old 05-01-2006, 04:35 PM
bobbytonic bobbytonic is offline
*giggles* @ High excursion subs with 12mm of xmax
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
