RE: whats the deal?
if your clutch is going out then usualy you can notice it start in the higher gears, like say you get up into 5th gear and start to give it gas, the motor will wind up but the car will feel like its slipping and not grabbing like it should be.... sounds like your throw out bearing could not be fully engaging the clutch so it is kind of like half engaged and trying to put it into gear which is bad because it will grind..
__________________
non-vtec ALL THE WAY
cylinder head guru!
