Go Back   HondaCivicForum.com > Your Ride > Engine & Internal > Swap Meet > ED-EF Swaps
Reply
Old 05-12-2006, 03:52 PM
mongochuy mongochuy is offline
Default whats the best swap for a 1989 si?
hey i just want some info. on what swap would be the best for the 1989 si. i was looking toward the h22 or the b18c5. but i have read that one is better than the other. what should i go for? THX for the info.
__________________
cLoNEe
Sponsored Links
Old 05-13-2006, 02:46 PM
yorky yorky is offline
Default RE: whats the best swap for a 1989 si?
b16 all day
__________________
88 4 door act street clutch
Old 06-04-2006, 06:27 PM
ef4life ef4life is offline
the h22 is a hard engine to fit and is costly because of all the parts you need. a b18c5 would be the way to go, but it will cost a lot also, but a much easier swap to do.
__________________
Old 06-05-2006, 11:47 PM
finalimpact finalimpact is offline
Send a message via AIM to finalimpact Send a message via Yahoo to finalimpact
h22........once its in and running its still cheaper than a type r swap, makes more power and has a broader power band. but for the cost of either you can build your si engine and turbo it then run circles around the h22 and c5 assuming you do the work yourself.
__________________
Old 01-09-2007, 01:33 PM
Powermidget Powermidget is offline
Send a message via AIM to Powermidget
both of those are going to require some custom fab...id go b16 gsr or ls to simplify your life and with the extra money boost that bitch
__________________
86 Bronco XLT ~ Blown Tranny&Motor(Ebay'd to Texas)
91 CRX Si ~ Totaled
90 CRX Dx(b16) ~ Jacked
96 LS Teg ~ Traded
91 HB B18a1~Blown Trans FOR SALE
93 Miata MX-5 56000 orig miles SWEET!!!
Old 01-09-2007, 01:42 PM
thread from the dead man, and a b18c5 type r is the same size and mounts as a b16 or gsr, so there would be no custom fab work.
__________________
Old 01-09-2007, 06:57 PM
Quote:
ORIGINAL: ef4life
pshhhh custom beating of the frame rail with a hammer FTW!!
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
