Go Back   HondaCivicForum.com > Your Ride > Suspension, Brakes, Tires & Wheels
Reply
Old 05-13-2006, 08:02 PM
xe1002 xe1002 is offline
Send a message via Yahoo to xe1002
Default brake wear
after growing tired of hearing my brakes squeal, i decided to replace the pads last night. after removing the old ones, i noticed that both pads for each side were wearing uneven. i was just curious as to what would cause this. they were the original pads from honda. also, i had noticed a sort of grinding sound coming from the right front whenever i would turn slightly and brake at the same time...dunno if that could have anything to do with it. any input is appreciated!
__________________
xe1002
Sponsored Links
Old 05-13-2006, 08:16 PM
mxs's Avatar
mxs mxs is offline
Administrator
Default RE: brake wear
Could be a wheel bearing? A shop told me that was the reason my rotors were wearing unevenly . . . it's a possibility.
How many miles are on your car?
__________________
Driving takes three abilities: Accelerating, braking, and turning. More power only helps acceleration. Lower weight helps all three.
PLEASE DON'T PM ME WITH TECH QUESTIONS, I WILL IGNORE YOU.
Old 05-13-2006, 08:18 PM
AgentofDarkness AgentofDarkness is offline
Send a message via AIM to AgentofDarkness
If the wheel bearings are bad, whenever you go over 30MPH you will hear an abnormal noise from the wheel. I don't get how a bad wheel bearing could cause uneven pad wear, some1 wanna explain that?
__________________
HCF Chat Rocks!!!!
Old 05-13-2006, 09:57 PM
mxs's Avatar
mxs mxs is offline
Administrator
now that I think about it . . . I don't know.
Did you regrease the caliper pins? They should both be sliding smoothly. If not, that could cause the pads to wear unevenly
__________________
Old 05-14-2006, 12:31 AM
didn't regrease the pins...
my car just turned over 61k. both sides wore the same way: the inside pad wore at a slant and the outside pad wore at the opposite slant....if that makes any sense. i figure i'll give the new pads a little bit of wear and then remove them to see if they are uneven too.
__________________
xe1002
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
