RE: 2 ohm /4ohm
Actually depends on the amplifier.. some ( not many) have a voltage regulator, that keeps the voltage steady no matter what ohm load you are running it at.. however, usually these amps, you do not get nearly as much of a power gain, when running at a lower ohm load. for instance I have a Blade amplifier Its a mono amp.. 175X1 at 8 OHM, 4 OHM, and 2 OHM... Tiny little amp.. NEVER got hot even.. lol always ran it at 2 OHM on 2 4 OHM kicker competition 12's
HD
__________________
1990 Honda Civic
Stock other than:
Stock Alternator Rebuilt to 114A (from 60A)
Optima Yellow Top Battery
