Go Back   HondaCivicForum.com > Your Ride > Nitrous, Super Chargers, & Turbos
Reply
Old 05-23-2006, 02:31 PM
slvcivic00 slvcivic00 is offline
Default Need a list of stock turboed cars!
Ok so I want to do a home made turbo set up on my Civic, mainly using junkyard stuff. So what types of turboes came off of what cars, for example: TD05-14b (gen. 1 eclipse). I am looking for a junkyard T3 turbo to strap onto my single cam civic. Any info on this stuff would be great, thanks.
__________________
The magic starts at 5500 RPM!
Sponsored Links
Old 05-23-2006, 03:24 PM
Nail I3unny Nail I3unny is offline
Send a message via AIM to Nail I3unny
Default RE: Need a list of stock turboed cars!
id rather go with a new garrett T3 turbine
but as for your question...DSM turbos and WRX turbos are the best stockers IMO.
Old 05-23-2006, 06:30 PM
Yeah good call on the DSM units, however they are too small, I want alittle larger turbo that will spool later, thus helping on fuel economy not having the BOV going off in between stop lights and making power to red line. Also the WRX turbos are harder to find, more expensive and harder to fabricate piping to.
__________________
Old 05-23-2006, 10:16 PM
riceburner700 riceburner700 is offline
Send a message via AIM to riceburner700
i know that ford put t3's in some of there cars back in the day, i dont know which cars they were but just do some research and one other thing thats cool is that they are 5 bolt downpipe flanges to
__________________
non-vtec ALL THE WAY
cylinder head guru!
Old 05-24-2006, 07:50 AM
Clean98EX Clean98EX is offline
ford put them in the thunderbird super coupe. you could find one of those pretty easy and its a good sized T3 turbo.
__________________
Black 98 Civic EX
AEM CAI
Apexi WS2 CatBack
Megan Header
PNP Head
Stage 1 Cam
PNP IM and TB
JR VPAC
15" RS limix rims/Nittos
Tein 1.2" inch drop
KYB GR2's
Old 05-24-2006, 11:38 AM
Good info guys, keep it comin, if they junkyard doen't have these cars then I need other cars as back-up. Thanks
__________________
Old 05-24-2006, 01:32 PM
what about 3000gt's? the twin turbo ones, dont know what turbo is on them but could probably use one of them...
__________________
cylinder head guru!
Old 05-24-2006, 02:17 PM
neon3kgt neon3kgt is offline
Send a message via AIM to neon3kgt
saabs? volvos? VWs
Old 05-24-2006, 02:20 PM
lilpooh21186 lilpooh21186 is offline
i used an ihi turbo for my 95 civic from a ford probe spools up by 2800 is set from factory for 7psi
Old 05-24-2006, 03:04 PM
MY99SI MY99SI is offline
Send a message via AIM to MY99SI Send a message via Yahoo to MY99SI
no matter what turbo set up u want your goin to need a BOV wheither it be plumbed back into the intake tract or not you need one. compresser surge is not good for the compressor blades and can eventually kill a turbo. compresser surge is when you close the throttle and the pressureized air that jus left the compresser housing has no where to go since the throttle is closed, where else does it go??? back where it came from. it damages the thrust bearings inside the turbo and eventually causes it to fail.
__________________
http://limaracing.myfastforum.org
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
