Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
need some help
  Printable Version
Honda Civic >> Your Ride >> Suspension, Brakes, Tires & Wheels >> need some help Page: [1] 2   next >   >>
Login
Message << Older Topic   Newer Topic >>
need some help - 5/16/2004 10:41:21 PM
SI_racer
Status: offline
SI_racer's photo gallery
hey whats up guys ! i have a 99 civic si ! i just installed some tokico struts and springs ! i have two questions 1) its not low enough should i cut a coil off and cut the bump stops in half ? 2) i want to buy a rear camber kit but there r two kinds u can get one looks just like a bolt with some washers ! the other one looks like a (T) and looks way more sturdy but i dont know what either one is for !! whats the diff between the two rear camber kits and what one should i get ?? thanks for ur help !!
Post #: 1
need some help - 5/16/2004 11:36:52 PM
slim11420
Status: offline
you start cuttin coils off and not only is your performance going to be affected but your ride quality is going to go to sh*t...i would look for different springs
(in reply to SI_racer)
Post #: 2
need some help - 5/16/2004 11:51:45 PM
NTX
Status: offline
NTX's photo gallery
Never cut coils out of the springs. Your cars ride will suck....a lot!
The rear camber Kit with the washers and bolts is called a progressive style kit. You add or subtract washers untill the rear angle is right. A lot of people like them cause they're cheap. If you know what to get you can go to a hardware store and probably pay less than $20 on parts. The other (T) shaped kit should be two halfs on a threaded sleave which allows the piece to be put in and adjusted on the car by turning the center with a wrench. It's more expensive but a lot easier to adjust if your ride height changes.
I have the (T) type on my car because i have adjustable coilovers. If you have springs and are not going to adjust the height, the washer type will work.
ntxmotorsports38123.9948726852
Post #: 3
need some help - 5/17/2004 2:12:20 AM
SI_racer
Status: offline
slim11420 ! do u know of any springs that give more than a 1 7.5 dropi have 17's on my car now and i want my car 2 sit right at the rim  ? i dont want to use coilovers cause i dont want to blow my struts i just bought tokico struts and springs !
Post #: 4
need some help - 5/17/2004 2:30:58 AM
SI_racer
Status: offline
ntxmotorsports check out that site is that all i need to fix my camber? and  he talks about toe pitch can you explain that plz !
http://home.earthlink.net/~civicex95/rearcamber.html thanks for your time
Post #: 5
need some help - 5/17/2004 3:46:10 AM
polo708
Status: offline
polo708's photo gallery
cut springs are the worst... they are dangerous
Post #: 6
need some help - 5/17/2004 3:28:15 PM
NTX
Status: offline
NTX's photo gallery
[QUOTE=SI_racer]ntxmotorsports check out that site is that all i need to fix my camber? and  he talks about toe pitch can you explain that plz !
http://home.earthlink.net/~civicex95/rearcamber.html thanks for your time [/QUOTE]
Thats what you'll need.
Whenever a car with indepenent suspension is lowered two things change, camber and toe. Toe is when the wheels start to point away from each other (like trying to turn left and right at the same time). Normally the front has this problem. Whenever you cange your ride height, you need to get four wheel alignment done. That will correct toe and make sure your camber is correct. You don't want to spend $500 a year replacing tires.
Post #: 7
need some help - 5/18/2004 1:57:35 PM
slim11420
Status: offline
these skunk2 springs will drop it...but you shouldnt have to worry about blowin your struts with coilovers....ive had ground control coilovers on tokico struts for over a year with no problem
http://www.nopionline.com/nopistore/dsp_part_detail.cfm?vmak eid=140&vmodelid=020&vcatyear=1999&vnopinum=591% 2B4903&vTitle=HONDA%20Civic%201999
Post #: 8
need some help - 5/18/2004 4:08:54 PM
green98lxsedan
Status: offline
green98lxsedan's photo gallery
never heard of rear ccplates b4. but new to the whole irs setups. but i guess with an irs it is a must.
cutting the springs is the ghetto way do do things.  dont do it. it f**ks everything up.
Post #: 9
need some help - 5/18/2004 6:50:24 PM
SI_racer
Status: offline
k ! thanks alot guys !! thanks for all the help
Post #: 10
Login OR Register now to post a reply to this forum topic.
Honda Civic Forum >> Your Ride >> Suspension, Brakes, Tires & Wheels
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414258
remmy11165
fiirkan10543
mill$civic8473
marty8273
mxs8006
fliphkd7207739
nail i3unny7705
sacicons7699
addiction2ba7491
New Vendors
K&N Engineering, Inc.
