Go Back   HondaCivicForum.com > Your Ride > Audio/Visual Electronics
Reply
Old 06-10-2006, 06:35 PM
n8te81 n8te81 is offline
Send a message via Yahoo to n8te81
Default wierd problem with amp....pls help
i finally got my subs hooked up and my monoblock going....so i know most of you have your gains set at a quarter and so thats what i did at FIRST. The dmm gain settings way wasnt working for some reason it kept reading the same numbers with the music going and the music off. Anyways i left the gains at a quarter for now and listened to it and i couldnt even feel the subs at high volume so i turned it up to half just to see the difference and then right as you get to half this HUGE rumbling comes from my subs and its constant even if the music is on pause....can someone pls help me with this.
here was a couple of things i was thinking...
1.preouts on pioneer HU
2.maybe bad ground
3.maybe need loop isolator???
Sponsored Links
Old 06-11-2006, 12:43 AM
moonbeam moonbeam is offline
Default RE: wierd problem with amp....pls help
i have a amp that dose that too. I think its a bad amp not the hook up. i always leave mine turned down and i dont have any problems then.
__________________
riboflaven@hotmail.com
Old 06-11-2006, 01:18 AM
well see the thing is....i had my other sub amp hooked up right before this one and i had the same problem just not as bad.
Old 06-11-2006, 11:09 AM
CivicEX06 CivicEX06 is offline
I would say check all your grounds and ****... mine was fine at lower volume but as soon i cranked it... kinda went funky... but i figured out insted of 12v i was getting like 6-7 because bad ground.... so check it and let us know
__________________
Need Custom website?
www.cytesbycynergies.net
Old 06-11-2006, 11:21 AM
when mine dose that i put a meter on it and it was reading 5 to 20 volts. my amp that i'm using dosn't do that but when i turn it up it cuts in and out and the speakers that are not hooked up to the amp dont make any noise either
__________________
Old 06-11-2006, 09:13 PM
i have a dmm.....where should i put it to check the voltage and what setting does it need to be at???
Old 06-12-2006, 08:59 AM
Remmy Remmy is offline
Administrator
get a voltmeter, check your power and ground wire. Look for any wires that are pinched...especially to metal. It sound like you got road noise to me.
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
