Go Back   HondaCivicForum.com > General Forum Information > New Member Introductions
Reply
Old 06-19-2006, 09:27 AM
ToRcHeD ToRcHeD is offline
Default Neutral A Bad Thing?
When I got my civic I bought it standard and I had to teach myself how to drive it... It's going well but when I want to slow the car down I simply shift it into neutral and press on the brakes... Is this hurting the car?
__________________
ToRcHeD
Sponsored Links
Old 06-19-2006, 10:28 AM
Ricky Fai Ricky Fai is offline
Default RE: Neutral A Bad Thing?
Don't shift to N as it will cause your gear box more easy to wear out. Just add pressure on the brake is OK, or to avoid brake overheat during downslope, shift the gear to "2" or even "1" to use engine brake.
Enjoy!
__________________
Ricky Fai
Old 06-19-2006, 10:33 AM
But how do I do that without making the car jerk? I tried it today and I almost had a head tumor lol...
__________________
ToRcHeD
Old 06-19-2006, 10:57 AM
Practice make perfect,
and maybe you can try to apply gradual pressure on brake more eariler.
The gearbox construction of a auto car is diff from manual one, it need trans oil for lub, and shift to N gear means the oil is pump away. Hence while still in rotation, the gear box rotate in low gear oil level condition, hence increase the gearbox wear and tear.
__________________
Ricky Fai
Old 06-19-2006, 11:34 AM
TicKeR_96_HaTcH TicKeR_96_HaTcH is offline
Just don't shift pre-maturally. Watch your RPM gage and shift down when it gets to around 1000RPM and it shouldn't jerk or just barely.. when you let go of the clutch while shifting down a, apply pressure on the gas pedal to keep you from dropping speed too quickly which causes the jerks.
TiCkEr
__________________
Old 06-19-2006, 11:53 AM
Mad7s Mad7s is offline
Send a message via AIM to Mad7s
How?
__________________
Always one ear to reality and one to the music.
RISK!
Old 06-19-2006, 01:06 PM
Robertsk8 Robertsk8 is offline
Send a message via AIM to Robertsk8
yeah really how? i drive in neutral all the time when i am coasting down a hill or if im lean on gass.
Old 06-19-2006, 01:24 PM
03civda 03civda is offline
I think Ricky Fai thinks Torched has an Auto Tranny.
Old 06-19-2006, 02:28 PM
neon3kgt neon3kgt is offline
Send a message via AIM to neon3kgt
when i downshift i rev up the engine to match what i assume would be the rev that it would be at. it makes it much smoother, and easier on the clutch.
Old 06-19-2006, 05:16 PM
bigdelscivic bigdelscivic is offline
i down shift when i come to a stop light or a stop sign. i love the sound of my exhaust when i do it. my RPM hit at 2000 when i do it. love the 5 spd.
__________________
1999 Honda Civic EX 5 spd. Coupe w/ sunroof
angel eyes
custom exhaust
JVC audio system
vibrant performance short shifter
1999 Honda Civic EX:
www.cardomain.com/2097179
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
