Will a high flow in line fuel pump be able to supply enough fuel for my b16A @ 7lbs of boost? do i need bigger injectors? fuel rail etc?? Right now i am sputtering at WOT high boost?????? Thanks for any help
i am running stock injectors and a fmu that came with my turbo and a high flow fuel pump. I already ordered rc 440cc for my baby. plan on soon (2 months) ordering the hondata unit maybe the S300 what do u think?? should i get tuned after i install my injectors or after the hondata ??? Thanks for ur help!!
You should probably get it tuned after the injectors. You should also upgrade the fuel management right now, FMU's (at least in my opinion) are pretty risky.
__________________
Don't PM me with tech questions
Antartic Blue Super Sports wagon with C.B. and optional Rally Fun Pack
Can u get a stock ecu tuned? My B16A came out of a 94 del sol so i guess I have an OBD1 correct? I always thought u needed to have something like hondata, neptune etc. in order to get tuned. Is my car gonna run like s*** with the 440cc injectors without a tune? Right now with just the bigger fuel pump it pulls good but you can tell it is holding back.
