It s on the way home!
I have a question. There is no need for modification right? just bolt it in? Some ppl told me that I need to weel or well or wheel something....I dont know. Help me guys!
__________________
WTB: 2000 SI INTAKE tube. OEM or aftermarket WELCOMED!
As long as you ordered the correct system it should be fine. The only complaint I've heard is that the center section tends to hang a little low but I don't know. When I get mine on, if it hangs to low I'll just take it down and make it fit right.
Why did you start another thread about this? There's already one going about your exhaust.
Quote:
ORIGINAL: POLYTHING
I have no idea what you are asking
__________________
Driving takes three abilities: Accelerating, braking, and turning. More power only helps acceleration. Lower weight helps all three.
PLEASE DON'T PM ME WITH TECH QUESTIONS, I WILL IGNORE YOU.
Did you mean weld? You shouldn't have to if you bought the correct exhaust system for you car. The only problem you may run into is getting the old bolts off.
