Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
tranny oil
  Printable Version
Honda Civic Forum >> Your Ride >> Transmission & Differential >> tranny oil Page: [1] 2 3   next >   >>
Login
Message << Older Topic   Newer Topic >>
tranny oil - 8/8/2006 3:27:35 PM
uk civhead
Status: offline
Thats right im going to be changing it soon so phoned my local honda dealer and they said they could sell me some from their workshop for £16 thats like nearly $30 which im thinking is quite expensive. he then said the technicians say just to put normal 10/40w oil in and it will do the job fine. what you think?
_____________________________
95 EG ESI hatch
CAI
Skunk2 I/M
62mm T/B
B&M short shifter
Megan 4-2-1 mani
2.25"custom stainless cat back
Spax psx sus,28 stage adj damping 40mm drop
megan strut brace
17"Wolfrace katana's
Toyo proxes T1-R's
Clifford G5 650 alarm
Post #: 1
RE: tranny oil - 8/8/2006 3:45:10 PM
ef4life
Status: offline
ef4life's photo gallery
i put oil in my tranny myself, not the honda stuff its too much money. so people will say only use the honda oil because it has special additives and stuff. never had a problem with the using regular motor oil.
(in reply to uk civhead)
Post #: 2
RE: tranny oil - 8/8/2006 3:50:38 PM
AgentofDarkness
Status: offline
AgentofDarkness's photo gallery
For a manual trans it not that important to use Honda fluid. However, i would recommend using something like synchromax or a synthetic oil. Synthetic oil is thinner and when the synchros are meshing with the gear, synthetic oil will leave the space b/w the synchro and gear alot faster than regular oil will.
HCF Chat Rocks!!!!
(in reply to ef4life)
Post #: 3
RE: tranny oil - 8/8/2006 3:55:40 PM
uk civhead
Status: offline
Thanks guys. il throw some synthetic magnatec engine oil in later this week when I do the tranny and engine oil.
95 EG ESI hatch
CAI
Skunk2 I/M
62mm T/B
B&M short shifter
Megan 4-2-1 mani
megan strut brace
Toyo proxes T1-R's
(in reply to AgentofDarkness)
Post #: 4
RE: tranny oil - 8/9/2006 6:36:09 PM
ej6buddy
Status: offline
ej6buddy's photo gallery
i know i'm being optimistic, but i just changed mine today, and i think you should use honda tranny fluid, they made the stuff for a reason. but i wouldn't recommend using regular engine oil in your tranny. btw, i got like 10 quarts for free from a buddy of mine at a dealership. haha
Post #: 5
RE: tranny oil - 8/10/2006 2:56:31 AM
AgentofDarkness
Status: offline
quote:
ORIGINAL: ej6buddy
And why is that? Honda sells Honda tranny fluid b/c people will buy it. Do you actually thing Honda makes its own oil? Honda engine oil is prolly really jus rebranded __________ oil. The only time you should be using Honda fluid is with honda AUTO trans b/c the auto trans is a hydraulic system and a different visconsity of oil will cause the trans to shift differently b/c the oil will leave the small spaces inside the trans at a different rate than the trans is programmed for. Engine oil is engine oil. Tranny oil only lubricates the gears and yes, you actually do use regular oil. Auto tranny fluid does ALOT more than lubricate gears so that is why you should only use Honda fluid. BTW HONDA recommends that 10W-30 or 10W-40 MOTOR OIL be used in the trans. That is straight from the service manual.
< Message edited by AgentofDarkness -- 8/10/2006 2:58:31 AM >
HCF Chat Rocks!!!!
(in reply to ej6buddy)
Post #: 6
RE: tranny oil - 8/10/2006 5:16:39 AM
finalimpact
Status: offline
finalimpact's photo gallery
ive used store brand 10w30 with no problems. i have even used 75w90 before with no problems. screw the honda mtf prices.
Post #: 7
RE: tranny oil - 8/11/2006 11:40:12 AM
ej6buddy
Status: offline
ok didn't know i was going to start a "bitch fight"! LOL! i'm just saying that it's recommended, but the oil is different, engine oil's main objective is to wet the seals and lubricate. tranny oil is made for the moving gears. but it really doesn't matter, unless you have about 200,000 miles on your car it doesn't even need to be changed, i changed it at about 79 K and it looked just like the new stuff.
(in reply to finalimpact)
Post #: 8
RE: tranny oil - 8/11/2006 1:55:02 PM
AgentofDarkness
Status: offline
Wrong again bud, engine oil and tranny oil is the same. If it wasn't the same then HONDA would not RECOMMEND using MOTOR OIL in thier transmissions. Tranny oil does not move gears, tranny oil lubricates the gears. The gears are moved by the engine. Remember we are talking about MANUAL transmissions. I would really like to see you prove that tranny oil moves gears. There is no pump in the manual transmission. I've seen a manual transmission taken apart and there is no possible way that the oil could move the gears. The oil sits at the bottom of the transmission and when the gears move they dip into the fluid and throw it around the trans by centrifigual motion.
HCF Chat Rocks!!!!
Post #: 9
RE: tranny oil - 8/11/2006 2:06:35 PM
ef4life
Status: offline
and the tranny oil stays pretty clean because there is no combustion going on in the transminssion, so no black carbon like engine oil.
Post #: 10
Login OR Register now to post a reply to this forum topic.
Honda Civic >> Your Ride >> Transmission & Differential
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414259
remmy11165
fiirkan10543
mill$civic8473
marty8273
mxs8006
fliphkd7207739
nail i3unny7705
sacicons7699
addiction2ba7491
New Vendors
K&N Engineering, Inc.
