Go Back   HondaCivicForum.com > Your Ride > Suspension, Brakes, Tires & Wheels
Reply
Old 09-04-2006, 06:30 PM
2002coupe 2002coupe is offline
Default Coilovers
I found a set of 4 shocks and drop springs on a 04 civic 2dr .My civic is a 02 so I was wondering if it fits on my civic .I can have them for sheep . I believe that the shoks are stock and the springs are eibach .
Sponsored Links
Old 09-04-2006, 09:58 PM
4door 4door is offline
Default RE: Coilovers
i would think there the same set up...ur best bet is to stop a deal with a 02 and look under it
__________________
http://www1.snapfish.com/slideshow/AlbumID=56984707/PictureID=1700126119/a=53403385_53403385/t_=53403385
Old 09-05-2006, 04:09 PM
Chimera02EX Chimera02EX is offline
Send a message via AIM to Chimera02EX
it's a spring and shock setup, coilovers are 1 piece. and yes it will fit.
Old 09-05-2006, 04:44 PM
03civda 03civda is offline
Actually, the crash bolts on the 02 are different than the 04 (14mm on 01 and 02, 16mm on 03-05). So technically they won't fit. Some people drill the holes out, but I would recommend against it. Good Luck!!!
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
