Go Back   HondaCivicForum.com > Your Ride > Engine & Internal
Reply
Old 09-19-2006, 03:49 AM
windcalmer windcalmer is offline
Default Valve springs, valves, and retainers???
This may have been posted before, but i could not find it after searching.
Starting with a stock D16Y8 engine, what would be the benefit of replacing the vavle springs, valves, and retainers? Does it just allow you to rev higher? Any HP or TQ gains?
Sorry if this is a really NOOB question.
__________________
Quote:
I know my environmental footprint is massive because I drive like and asshole!
Sponsored Links
Old 09-19-2006, 05:33 AM
Street Sniper Street Sniper is offline
Default RE: Valve springs, valves, and retainers???
Rev higher- yes, hp/tq gains- no. Now if you replace the cam in order to use those extra revs, then yes on the hp/tq, but the gains will be had from the extra lift/overlap moreso than the revs. Of course if you plan to go past 7200 rpm you will need stronger rods too.
__________________
Tuned by G-Tech... Powered by YooHoo.
Quote:
...there's more than one way to skin the horsepower cat.
Old 09-20-2006, 04:41 AM
So for an all N/A build I should do a cam and the rods and pistons? What kind of gains can I get from a this type of build?
__________________
Old 09-20-2006, 04:49 AM
mentaldis0rder mentaldis0rder is offline
Send a message via AIM to mentaldis0rder
Check the engine section under building a D series.. shows a decent base walkthrough of what you can do.. power for a good build on streetable car 140-160whp
__________________
1996 CX Hatch.. Click below for mods!!
Work In Progress
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
