Go Back   HondaCivicForum.com > Your Ride > Transmission & Differential
Reply
Old 09-27-2006, 09:27 PM
LostCivic LostCivic is offline
Default Axles!
I hope I posted in the right secting? I need to change my axles out but the problem I have run into is rusted BRIGHT ORANGE axle bolts. If anyone doesn't know what I'm talking about it's the bolts that goes on the end of the axles. I have tired WD-40, PB blaster, 4 heavy duty craft-man rackets (breaking as I try to take it off). What should I do? I'm thinking about cutting the bolts after I torch the bolts till they are red. What do you guys think?
__________________
Need some work!
Sponsored Links
Old 09-27-2006, 09:30 PM
ef4life ef4life is offline
Default RE: Axles!
did you get a breaker bar? i used a 2 foot bar and a longer pipe on it to break mine loose, and or use a heavy duty impact.
__________________
Old 09-27-2006, 09:42 PM
Default RE: Axles!
I forgot to mention that I also broke 4 breaker/cheater bars!
__________________
Need some work!
Old 09-27-2006, 11:25 PM
Misha Misha is offline
Default RE: Axles!
I might be missing something, but all cars I happen to remove axle from had a NUT not a BOLT at the end of axle.
If this is a nut, it has a dent, going into the groove on the axle end, to prevent the nut from loosening. You need to use flat screwdriver with hammer, or other suitable (or even special) tool to remove the dent first, then it will be possible to loosen the nut witha good extender.
__________________
Love you guys
-- Be safe --
Mapquest Driving Directions
Defensive Driving
Old 09-28-2006, 07:50 PM
sacicons sacicons is offline
Default RE: Axles!
yeah, unstake the dent first if you havent already, but im thinking the orange isnt rust, its paint that the last installer used to tell if someone messed with the bolt in case of warranty issues. its so you cant have someone work on your car, then loosen the bolts and blame them when something falls off.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 09-28-2006, 09:26 PM
SpanishFly21 SpanishFly21 is offline
Send a message via AIM to SpanishFly21 Send a message via Yahoo to SpanishFly21
Default RE: Axles!
wont u try one of those air pressure guns....get an air compresser and see if that works...
__________________
WE DONT DO THINGS WE LOVE HALF FAST-
ELITE STYLES
Old 09-29-2006, 10:30 AM
AgentofDarkness AgentofDarkness is offline
Send a message via AIM to AgentofDarkness
Default RE: Axles!
Quote:
ORIGINAL: SpanishFly21
Otherwise known as an impact gun. I had the same problem when i was trying to change my axle. I couldn't get the bolt out for anything with the breaker bar i had. I got an impact gun and it came out in like 2 sec.
__________________
HCF Chat Rocks!!!!
Old 09-29-2006, 07:53 PM
Default RE: Axles!
I have a 250psi tank and a impack gun...doesn't work. I've already used the flate head and hammer to remove the dent. I'm not trying to be ass but it's very frustrating. I've already done everything that everone has mention. Could it be that my craftmen impact gun is weak....and have to use a heavy duty truck one?
__________________
Need some work!
Old 09-29-2006, 08:26 PM
Default RE: Axles!
Are you trying to rotate it in the correct direction?
__________________
Love you guys
-- Be safe --
Defensive Driving
Old 09-29-2006, 08:35 PM
Default RE: Axles!
there's only one direction to take nuts of and thats to the <---------------LEFT
__________________
Need some work!
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
