Go Back   HondaCivicForum.com > Your Ride > Nitrous, Super Chargers, & Turbos
Reply
Old 10-02-2006, 10:05 PM
redridinhood redridinhood is offline
Default 8lbs = bigger injectors?
gettin some stuff bought for my jackson supercharger and i was just wandering if i would need bigger injectors at 8psi if so what size so im not runnin lean and killing my motor thanks!
__________________
Sponsored Links
Old 10-02-2006, 10:17 PM
Remmy Remmy is offline
Administrator
Default RE: 8lbs = bigger injectors?
No. The beauty of JR s/c is they are perfectly designed for stock honda engines. They require no major modification. They are a 'set it and forget' application. Bigger injectors would only be needed to run 10psi or more typically.
Next time I do a boost application, it will most likely be a s/c. Reliability, simplicity and no frills (in a bad way) is what makes a s/c great.
*For the turbo people, I know about tune this and tune that, but from what i stated above a s/c is superior to a turbo in that manner. No need for arguement, its been discussed millions of times so you all should know where im coming from.
__________________
Old 10-02-2006, 10:34 PM
ya thats why i went the s/c route the simplicity and low matenance (sp) lol
__________________
Old 10-02-2006, 10:39 PM
drbyers drbyers is offline
i love jackson racing stuff. too bad they're SO DAMM EXPENSIVE... lol.
__________________
Old 10-02-2006, 11:04 PM
ya tru but ebay has some good deals on jackson stuff
__________________
Old 10-02-2006, 11:55 PM
Administrator
I have foudn the ebay thing isnt that much less expensive than the jrsc quotes off the web
__________________
Old 10-03-2006, 03:24 AM
herbaleyes herbaleyes is offline
I looked at the Civic s/c and it looks like you can even run 8psi on a stock d, no?
Old 10-03-2006, 09:01 AM
Administrator
Bone stock. Wait... im not sure. out of the box it will do 6psi...which you can run bone stock. You have to get an underdrive pulley to get 2 more pounds out of it but theres something else you need to do for that.... I just cant put my finger on it.
__________________
Old 10-03-2006, 09:23 AM
Fiasco Fiasco is offline
Send a message via AIM to Fiasco
you can definately find JRSC kits on ebay much cheaper than list if youre patient. They come and go, but theyre out there. I had a guy offer me a kit with injectors, intake and a fuel pump for 900 bucks.
__________________
Old 10-03-2006, 11:26 PM
SovXietday SovXietday is offline
Send a message via AIM to SovXietday
This is simply what I would recommend.
6psi, JR MAP controller, and stock injectors is driveable. Notice I didn't say smooth, it's jumpy and tends to miss a lot, especially at lower RPMs.
8psi really should get a tune. You will make a lot more power, and the car will be a lot more drivable with a good tune.
Oh, and I'm running 8psi on a t3t4 57 trim with no issues and a stock block... building an engine for an SC is pretty much just optional. Like everything, it just needs a good tune...
Look into getting it intercooled though...
__________________
Champ White 1996 Civic Hatchback - 57trim SOHC
Black 1998 Z28 Camaro - LS1 M6
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
