Go Back   HondaCivicForum.com > Your Ride > Engine & Internal
Reply
Old 10-26-2006, 09:31 PM
t34me t34me is offline
My Garage
Default HELP PLEASE
Ok guys, i got the new injectors in today, and tried to crank her up. No go. I wanted to cry. The only good thing is i dont have gas spilling out the exhaust side of the turbo. So, here is the deal, the engine cranks over and when i put the gas to the floor, it kinda sputters like it really wants to start, but as soon i stop hitting the ignition button, it dies. Im at a total loss, and i dont know if my brainstorming is off the wall, or there may be somthing to it. SO, im going to throw a few things out there, let me know if any sound legit.
1. To big spark plug gap-running vitara pistons with .30 gap
2. Wires are shot (not plugs, i just put the new ones in)
3. Cap and rotor-looking at possible MSD coil and cap
4. Unknown Vector
Any suggestions would help guys, im ready to just give up, but ive come this far, so i want to see my time, money, blood, and sweat pay off.
__________________
[quote]ORIGINAL: Ohiocivic
this might be the best thread of the year.
t34me: you are the man, because i said so, now put that in your sig and smoke it. LOL
Sponsored Links
Old 10-26-2006, 10:39 PM
StifflersMom's Avatar
StifflersMom StifflersMom is offline
HCF Village Idiot
My Garage
Default RE: HELP PLEASE
do you have fuel pressure? Check if you actually have spark in all cylinders, make sure your wires are going to the correct cylinders....you know, the basics. To me if you have spark and fuel it sounds like timing or firing order.
__________________
Gimme some love, shuga'
Old 10-27-2006, 12:03 AM
My Garage
Ok, i post on D-series.org as well, and some people are telling me my timing(sp) is 180 degrees off. Does this sound like it could be the culprit? I know for a fact that the block was at tdc due to the head being off, i could line it up using the marker and seeing the piston. The head though, i would have put money that it was at tdc, but with the replies ive been getting, im starting to get worried. IF this is the problem, what would be the easiest way to test/fix it?
__________________
Old 10-27-2006, 09:46 AM
HCF Village Idiot
My Garage
timing being 180* off is definitly a possibility. you'll just have to redo the timing.
__________________
Old 10-27-2006, 10:19 AM
My Garage
ok, this is going to sound stupid. I can rebuild a damn motor, but get confused when it comes to the timing issue. Are you talking about 180* on the cam? or the distributor? Like, do i have to take off the belt and rotate the cam 180 OR rotate the distributor 180? If it is the distributor, how do i rotate it 180 and still get it to fit? Wont it only slip into the end of the cam one way because of the notch? I know i sound retarted, but at this point i really dont care, i just want my car
__________________
Old 10-27-2006, 11:06 AM
Misha Misha is offline
My Garage
Everybody has a right for a temporary lapse of reason
You did a great job, man, just a bit more to go Take your textbook and find the chapter about timing belt replacement. Start from scratch and make sure your camshaft is in sync with your crankshaft. And distributor can fit only one way, you can't have it wrong here
__________________
Love you guys
-- Be safe --
Mapquest Driving Directions
Defensive Driving
Old 10-27-2006, 11:14 AM
drbyers drbyers is offline
My Garage
that's a pretty clean looking setup you got there. good luck.
__________________
Old 10-27-2006, 03:21 PM
My Garage
thats just it though, i know i had it right because when i took off the head, i had the #1 cylinder at TDC, and on the head, the intake valves were just opening for the intake stroke on the #3 cylinder. So when i put the head back on, again the block was at TDC, and i reinstalled the cam, and cranked it around till it came to rest on the intake for cylinder #3. So when people are saying 180 off, are they talking about ignition?
__________________
Old 10-27-2006, 06:27 PM
MY99SI MY99SI is offline
My Garage
Send a message via AIM to MY99SI Send a message via Yahoo to MY99SI
what kinda injectors are they?
if you got dsm's then you prolly need a resistor box
__________________
http://limaracing.myfastforum.org
Old 10-28-2006, 01:35 AM
My Garage
they are stock d16z6. All i want to know is what is meant by timing is 180 off?? Also, could this scenario be a possibility:
When the car was parked it was on empty, and it has been sitting for 2 months. Could moisture have built up, or maybe the gas broke down?a
__________________
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
