HondaCivicForum.com
-   Transmission & Differential (https://www.hondacivicforum.com/forum/transmission-differential-39/)
-   -   3rd gear grind? (https://www.hondacivicforum.com/forum/transmission-differential-39/3rd-gear-grind-31531/)
civic_66 Oct 27, 2006 11:37 PM
3rd gear grind?
hey guys i think i got a problem with my tranny. when i shift at low rpms into 3rd gear its fine but once i get the revs up and switch to 3rd it has just a little grind. i just bought a rebuild kit and bushings for the shifter cause it is extremely sloppy. so could it be that? or is my tranny ****ed? and how much $ am i looking to fix it? and can i still drive it like that?
Misha Oct 28, 2006 12:34 AM
RE: 3rd gear grind?
it's a syncro sleeve. I drove my 84 with that for quite a few thousand miles before I got a chance to open the tranny
riceburner700 Oct 28, 2006 10:39 AM
RE: 3rd gear grind?
cycnros are what mesh the gears together. so replace those and she should shift like butter unless something is bad
civic_66 Oct 28, 2006 10:44 AM
RE: 3rd gear grind?
and the cyncro sleeve is where? in the transmission? is it an easy installation? thanks
Misha Oct 28, 2006 10:54 AM
RE: 3rd gear grind?
yes, it is there. no, it is not easy install. you have to remove and completely disassemble your tranny:( if you are asking this question, you are better of getting it replaced for you:)
finalimpact Oct 28, 2006 01:10 PM
RE: 3rd gear grind?
before you go out and tear the tranny apart look into the easy stuff.....bad shifter bushings can cause it, bad motor mounts can cause it, low or bad oil can cause it. if all these fail then be prepared to have the tranny pulled apart.
Misha Oct 28, 2006 02:04 PM
RE: 3rd gear grind?
since this is third gear, I'm pretty much sure it's a syncro. I believe it's a known problem for civics. but really a good idea to try easier and cheaper things first, agree 100%.
ef4life Oct 28, 2006 02:05 PM
RE: 3rd gear grind?
haha it was always second gear for me until i grew up:D
riceburner700 Oct 28, 2006 09:11 PM
RE: 3rd gear grind?
think your honda has bad grinds, dont ever own a dsm, you will pull your hair out with those damn trannys:D but man are those cars fast modified:D
finalimpact Oct 28, 2006 11:14 PM
RE: 3rd gear grind?
ORIGINAL: riceburner700
which is why my dsm is an auto :D
