Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
How to install a lip kit
  Printable Version
Honda Civic Forums >> General Automotive >> DIY - Do It Yourself >> Exterior Modification DIYs >> How to install a lip kit Page: [1]
Login
Message << Older Topic   Newer Topic >>
How to install a lip kit - 10/29/2006 8:19:03 PM
mill$civic
Status: offline
mill$civic's photo gallery
Most lip kits are the same to install. Very easy and only a few steps
1. Tools needed, drill with drill bits, screw driver and screws, 2 bolts if you want and M3 double sided tape if you want (read on.)
2. Add some double sided M3 tape to the back of the lip kit where the kit contacts the bumper if you want, it keeps it in place, if not, just have someone hold the lip kit in place wile you line up the tabs at the end of it inside your wheel well. Make sure you like the way the kit is position before sticking it on or making the holes.
3. Now you just need to make a SMALL hole with a drill bit on the inside tab through the tab and the bumper, then add a bigger screw in that hole to hold the lip kit to the bumper. For added protection, I added another hole with the drill bit and put in a bolt into, so if someone tries to steal the lip, it will be a little challenge, you could also add rivets which would even add more protection.
That’s pretty much it, a very easy install. This also applies for the rear bumper.
Good luck! Mill$civic
Thumbnail Image
Thumbnail Image
Thumbnail Image
Attachment (3)
_____________________________
Member since Feb 2005
Post #: 1
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414155
remmy11161
fiirkan10322
mill$civic8433
marty8262
mxs8005
nail i3unny7705
sacicons7674
fliphkd7207589
pete7169
New Vendors
K&N Engineering, Inc.
