We're adding and testing new features:  Create your Garage, used it? Give us some feedback here.
Go Back   HondaCivicForum.com > Your Ride > Transmission & Differential
Reply
Old 11-14-2006, 10:22 AM
FlipHKD720's Avatar
FlipHKD720 FlipHKD720 is offline
My Garage
Send a message via AIM to FlipHKD720
Default 99-00 Intergra/SI Axles into a 99 2dr
I have quite a few questions about swapping axles, because i am REALLY looking into a b16a2 swap into my '99 DX Coupe, and i know you need to axles to do this swap. I know you either need 99-00 Integra or SI axles for this, so here are my questions:
- When you swap axles, can you still use the same brakes, or do you need to buy new ones?
- Does the suspension (springs, shocks) from my car fit with the new axles?
- Is the actual swapping of the axles one of the hardest parts of this swap? (seems like it would be)
And can anyone give me a link to a write-up that includes the swapping of the axles? I think i can handle the engine, tranny, and ECU, but the swapping of the axles seems pretty intense. Thanks all!
__________________
Old 11-14-2006, 10:35 AM
mxs's Avatar
mxs mxs is offline
Administrator
My Garage
Default RE: 99-00 Intergra/SI Axles into a 99 2dr
1. your hubs will still work, exception being if you swap in a later JDM type r, which uses 36mm instead of 32 (I think). also, if you r car has ABS, you need ABS axles; if your car does not have ABS you can either use non-ABS axles, or use ABS axles and modify them.
2. they don't touch, it's fine, you're not swapping the hubs
__________________
Driving takes three abilities: Accelerating, braking, and turning. More power only helps acceleration. Lower weight helps all three.
PLEASE DON'T PM ME WITH TECH QUESTIONS, I WILL IGNORE YOU.
Old 11-14-2006, 11:54 AM
FlipHKD720's Avatar
My Garage
Well i dont got ABS, so i have to buy Non-ABS specific axles?
So i really dont need to touch anythign except the actual axles themselves?
Thanks for the info MXS!
__________________
Old 11-14-2006, 12:11 PM
mxs's Avatar
mxs mxs is offline
Administrator
My Garage
Quote:
ORIGINAL: mxs
the axle has a ring with teeth for the ABS sensor, you can remove it if you don't have ABS.
__________________
Old 11-14-2006, 01:23 PM
HARI. HARI. is offline
My Garage
Send a message via AIM to HARI.
Quote:
ORIGINAL: FlipHKD720
easy to do. jack up the car and put it on jackstands.
take the wheel off.
take the 32mm or 1 1/4 nut off the axle.
take the fork off the lower control arm. you need a 17mm socket and rachet to take it off.
take the cotter pin and the 17mm castle nut off the lower ball joint.
take the ball joint off the lower control arm. this might be a lil hard to do. don't use the ball joint separator that looks like a big ass fork. this will rip your ball joint boot. what you do is:
jack up the wheel hub enough for it to go up, and wedge an open wrench, or your 3/8 rachet in between the ball joint and lower control arm. lower the jack and move it out of the way. now kick the wheel hub at the top and that should separate the ball joint from the LCA. swing it out of the way.
now your axles are ready to come off. you might have to pry it off w/ a flathead screwdriver from the tranny. good luck. let us know how it goes
__________________
need any used parts.....hit me up i can probably help you
MY FOR SALE THREAD
Old 11-14-2006, 02:48 PM
FlipHKD720's Avatar
My Garage
Thanks man, thats exactly what i was looking for. Well i'm not gonna start teh swap for about a year, but when i do, i think i'll dedicate a thread just to the swap itself. Should be good though
__________________
Old 11-19-2006, 06:13 PM
FlipHKD720's Avatar
My Garage
Alright one more question. Since my car is just FWD, do i need to swap rear axles too?
__________________
Old 11-19-2006, 07:09 PM
mxs's Avatar
mxs mxs is offline
Administrator
My Garage
You don't have rear axles........ because your car is FWD
__________________
Old 11-19-2006, 08:33 PM
FlipHKD720's Avatar
My Garage
damn i feel like a n00b.....[&:]...alright MXS, dont the wheels bolt right onto the axles? If not, what are those called?
....and then whats the axle?!
__________________
Old 11-19-2006, 08:45 PM
mxs's Avatar
mxs mxs is offline
Administrator
My Garage
You say you can handle the swap yourself, but take a look at your drivetrain first ... the axles just connect the transmission to the hub assembly, and you only have axles in the front. the rear has no axles, the hubs are just attached to the suspension
__________________
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
