power steering
yeah, quick question, i was just wondering how do i remove the power steering belt without cutting it, do i put a screwdriver or something in the pulley and a 19mm socket/ratchet on the end and turn it? if so which way.
thanks |
RE: power steering
yeah its really easy. there a bold that hold it tight and a bolt used to slide it up and down as you turn it. losen the bold on the bottom and then the bolt on top slides it up and down. turn it out so it goes down and you should be able to pull it right off.
RE: power steering
Yort, it is always helpful to tell which model and year of your ride.
RE: power steering
1998 d16y7
| All times are GMT -8. The time now is 06:11 PM. |
