Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
Upper Control Arm Replacement by Fiirkan
  Printable Version
Honda Civic Forum >> General Automotive >> DIY - Do It Yourself >> Drivetrain DIYs >> Upper Control Arm Replacement by Fiirkan Page: [1]
Login
Message << Older Topic   Newer Topic >>
Upper Control Arm Replacement by Fiirkan - 11/23/2006 1:48:23 AM
Remmy
Status: offline
Remmy's photo gallery
Big thanks to Fiirkan for this DIY submission!
This DIY is for 92-95 civic, it should cover all models.
What you will need.
Ratchet (but I highly recommend an impact gun if you can get access to one)
17mm socket
14mm socket
17mm wrench
2 14mm wrenches.
Jack and stands, if you have access to a lift use it. it makes things easier.
Step One: Jack the car up and take the wheel off. Pull out the cotter pin and take off the nut.
If the threaded part does not pull out, hit the steering knuckle with a hammer, not the control arm just in case the one you have is the wrong one and you have to reuse the old one.
Drop the suspension by taking off the two 14mm bolts.
Now take off the two bolts holding the control arm to the strut tower(highlighted in blue). You may have to move the throttle cable to get access to one of the bolts for the control arm. If you are using a ratchet or wrench, it shouldn't be an issue. With an airgun or impact gun you will have to move it.
You should now be able to pull out the control arm, it may take some maneuvering to get it over the suspension.
Installation is the reverse of removal. Be sure that the bolts (highlighted in yellow in pic 1) are tightened, as they don't tighten all the way when you buy it. I suggest tightening them once the control arm is on so that it will be at the proper angle. Tighten them snug or else there will be an awful racket from it when driving.
_____________________________
Post #: 1
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Honda Civic >> General Automotive >> DIY - Do It Yourself >> Drivetrain DIYs
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414155
remmy11161
fiirkan10322
mill$civic8433
marty8262
mxs8005
nail i3unny7705
sacicons7674
fliphkd7207589
pete7169
New Vendors
K&N Engineering, Inc.
