We're adding and testing new features:  Create your Garage, used it? Give us some feedback here.
Go Back   HondaCivicForum.com > Your Ride > Transmission & Differential
Reply
Old 11-24-2006, 07:11 PM
ic892003 ic892003 is offline
My Garage
Default 2nd gear shift problem
i have recently noticed iit has become harder to shift into 2nd gear.. i have 2 use more force, what can cause this, someone told me i should get a transmissiion flush, but not sure any advice would be helpful
__________________
Sponsored Links
Old 11-25-2006, 04:20 PM
My Garage
Default RE: 2nd gear shift problem
nobody have an answer??? ok basically it is harder to move the stick into 2nd gear when going from 1st. i dunno what it could be shifter bushings maybe'??
__________________
Old 11-25-2006, 04:32 PM
GetItBoy GetItBoy is offline
My Garage
i have the same problem! especially when im tryin to shift to second from a high rpm. i dont think to much of it tho. sorry i couldnt help, but maybe someone will help us both!
Old 11-25-2006, 05:12 PM
My Garage
how long have u felt this change in ur shifting?
__________________
Old 11-25-2006, 05:15 PM
Misha Misha is offline
My Garage
If this would have been third, I would say syncro sleeve without any doubt - this is a known honda problem. Your case is most probably syncro sleeve, too. Might be a shifter linkage, though. If this is your tranny, filling it with somewhat heavier oil may help temporarily, but ultimately you have to rebuild it to fix this.
__________________
Love you guys
-- Be safe --
Mapquest Driving Directions
Defensive Driving
How to Beat A Speeding Ticket
Old 11-25-2006, 05:41 PM
My Garage
when i shift into 3rd it is a litttle difficult as well, so what does this mean?? and how much does the synchro sleve cost to replace??
__________________
Old 11-25-2006, 05:55 PM
My Garage
IDK, I did it myself. Sleeve itself costs a few bucks, but the job is to remove the tranny, completely disassemble it, assemble and install....
__________________
Love you guys
-- Be safe --
Defensive Driving
Old 11-25-2006, 06:05 PM
My Garage
ok thanks for the help i guess next time i see my mechanic ill get it checked out
__________________
Old 11-25-2006, 08:58 PM
riceburner700's Avatar
riceburner700 riceburner700 is offline
My Garage
Send a message via AIM to riceburner700
try changing your tranny oil and that should help out a lot. use either gm syncromesh or genuine honda mtf or if you cant afford either use some high quality 10w30
__________________
cylinder head guru!
Non Vtec power
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
