well if its a paging system im preaty sure it would have a toggle switch if properly instaled.... BUT it might not....
but the paging remote control SHOULD say a name... you shoulda got a secondary standard remote control as well which it shoulda also had a name on it.... if thiers no name its gotta be a cheap rip off one....
but like i said check out the alarm system under the dash and find the larger wires.... if they are just conected to the factory large wires then you should just be able to cut the starter wire from the alarms brain or relay modual... and then try and start the car with the key if she starts your golden... if not track down the wiring more... it might be a green or purple wire which will also be large.
but if your not comfortable with doing it or even trying it... just take it to bestbuy or someplace that instals alarm/remote starter systems and just ask em how much they would charge to disable the starter wire........
this way if you only disable the starter wire youll still have the stop and go feature.....
so you can have the car running... push the brake pedal down, press the remote start button on the remote control and then turn the key off and the engine will or SHOULD still be running so you can run into a place and keep the car runnen without the keys in the ignition... and then jump back in the car put the keys back in and go
nice feature for ATMs, banks, or any quick in and out run.........
youd just have to be sure to keep it in nuetral and the Ebrake when geting out.... which shoul dbe easy enough...LOL
i wouldnt think they would charge to much just to take one trim panel off and cut one wire..... but best way to find out is to go and ask....
just tell em you only want the starter wire cut.....
and youll be golden! they should definatly know if its got a starter kill or not and how to put it back stock if it is...
since it doesnt sound like you know much about wiring thats what id sugest!
you dont wanna cut the wrong wire and not know how to fix it
