Go Back   HondaCivicForum.com > Your Ride > Nitrous, Super Chargers, & Turbos
Reply
Old 11-29-2006, 09:54 PM
impreCiV impreCiV is offline
Default whats the point?
ok ive got a few questions, first whats the difference in performance between having a big turbo over a small turbo, like i know the bigger u go the more lag u have but why go bigger turbo? and also whats ctr or itr?
Sponsored Links
Old 11-29-2006, 09:55 PM
Default RE: whats the point?
ok figured it out, civic type R and integra type r
Old 11-29-2006, 11:29 PM
riceburner700 riceburner700 is offline
Send a message via AIM to riceburner700
bigger can push more hp top end than a smaller turbo...
__________________
non-vtec ALL THE WAY
cylinder head guru!
Old 11-29-2006, 11:31 PM
SovXietday SovXietday is offline
Send a message via AIM to SovXietday
Think of a turbo as an air pump, the larger the pump the more air can be moved. The more air entering your engine the more horsepower you can make. Also, larger turbo's take less heat and less energy to compress the same amount of air than a smaller turbo, less heat = denser air = more power. Smaller turbo's also choke up and restrict exhaust flow easier than large ones, limiting horsepower by not letting the used air out of the engine.
__________________
Champ White 1996 Civic Hatchback - 57trim SOHC
Black 1998 Z28 Camaro - LS1 M6
Old 11-30-2006, 03:03 PM
MY99SI MY99SI is offline
Send a message via AIM to MY99SI Send a message via Yahoo to MY99SI
in my opinion i would start off with a larger t-3/to4e so that way over time you have room if you ever want to up the boost when you have the mods to enable yourself to go faster
__________________
http://limaracing.myfastforum.org
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
