We're adding and testing new features:  Create your Garage, used it? Give us some feedback here.
Go Back   HondaCivicForum.com > Your Ride > Audio/Visual Electronics
Reply
Old 12-03-2006, 12:30 AM
03civiclxcoupe 03civiclxcoupe is offline
My Garage
Send a message via AIM to 03civiclxcoupe
Default wiring to battery and lights?
can anyone tell me how i can hook up LEDs or neons or fog lights in my car that will turn on and off with my headlights? 2003 civic lx coupe...thanks in advance
__________________
2003 Honda Civic LX Coupe Rallye Red
7th Generation EM2 D17A1
K & N Typhoon SR Intake
Alpine CDA-9856
Polk Speakers DB690 DB6900
Profile 80x4 Amplifier
17" Exel Speed w/ 215/45/17 Hankook Radials
Sponsored Links
Old 01-26-2007, 09:51 AM
My Garage
Default RE: wiring to battery and lights?
bump
__________________
Alpine CDA-9856
Old 01-26-2007, 09:58 AM
JLguy JLguy is offline
My Garage
Send a message via AIM to JLguy
look on ure interior fusebox map, find the circuit that is controlled by ure headlight switch, and wire the power wire right into that fuse slot(wrap the wire around the fuse post) and find nearby ground(the shorter the distance from the actual light the better)
__________________
If knowledge is dangerous, where is the man that has so much knowledge as to be out of danger?
Old 01-26-2007, 11:01 AM
FlipHKD720's Avatar
FlipHKD720 FlipHKD720 is offline
My Garage
Send a message via AIM to FlipHKD720
+1 for wiring into the fuse box, get a manual and see which fuses get power when, or just use a voltmeter/multimeter to check which fuses are on
__________________
Old 01-26-2007, 01:36 PM
Red Hot Rider Red Hot Rider is offline
My Garage
Send a message via AIM to Red Hot Rider
RELAY! Use a relay! Trace the wire from your headlights, actually I used my parking lights as a power actuator. Get a standard relay, probably from local auto store, should come with a schematic. Most SPST relays are simple to use, and can be the difference from a proper installation and a fire hazard.
If the relay you pick up has a pin marked 87a in the center, simply ignore it for this installation. Use at least 14ga wire, if not 12. I normally use 12ga when wiring up accessories. Pin 30 needs to be a 12v source, usually your battery. Utilizing existing 12v sources to power your new accessory, can lead to car fires, unless you use an hot blank in your fuse panel. Probably not, but I don't like to take chances like that. Pin 85 is simply a ground, nice and clean with no paint or crap on the metal. Pin 86 will draw minimal current from an actuator source, and you can safely use 14ga here. What I mean by actuator source, is something that needs to be on in order for the accessory to work. I normally use my parking circuit for fog/driving lights, as I don't care to branch off of the headlight circuit. Pin 87 will be the + for the fog/driving lights. Then povide a ground for the lights as well, preferably not the same ground as the relay.
__________________
Old 01-26-2007, 01:47 PM
My04Civic's Avatar
My04Civic My04Civic is offline
Administrator
My Garage
wire them to a switch
__________________
Old 01-26-2007, 01:57 PM
badb0ybilly badb0ybilly is offline
My Garage
lol my04civic. thats what i'd say. its easier that way. but i see where 03civiclxcoupe is coming from. its cool when people get in your car and things just happen to make everything look pretty. if you have to spend time flipping switches, then it takes away theeffect.
but i wanna say to 03civiclxcoupe. be careful if you're going to wire your interior lights to your head lights. check your state laws because lets say the 5-0 has his eye on you, and interior neon's are illegal in your state, theres no way you can turn them off without turning your headlights off. you COULD if you wanted to get technical, wire an incon****uous switch thats always on, and wire it to the headlights. that way you have the option of just turning the neons off if you need to, but as long as the switch is always on, the circuit will always be complete when you turn your headlights on so you get the same effect. but as far as the actual wiring to the headlights im not sure how that works. but im curious to find out.
__________________
Old 01-26-2007, 09:59 PM
Stumasters Stumasters is offline
My Garage
Send a message via AIM to Stumasters
I am bad about wiring up switches myself, without the use of relays, because they confuse me sometimes, plus its just boring trying to install them, but lets say you did throw a switch on this example you provided, for the sake of knowledge, how would you do that?
I am thinking you would just run the actuator + source to the grounded switch, then run another wire from the switch to the actuator + relay entry?
And what is the purpose of the relay anyway, do they have some sort of internal fuses? I know they are better suited to run higher power items. But wouldn't an inline fuse perform roughly the same?
And, lol I am full of questions on this subject.. If you do run the relay through a switch, wouldn't the switch still be getting the entire 12V flow (is that dangerous). I know you said the actuator input wouldn't use as much power..
Just trying to get some clarity, I need to throw a few in my car :-)
__________________
American cars
Thanks to Windcalmer for the sig!
http://www.geocities.com/black97civic
Old 01-26-2007, 10:54 PM
My Garage
Quote:
ORIGINAL: Stumasters
Switch should be mounted between the actuator source and pin 86. This way the relay is not activated unless the actuator source is hot. This also allows you to run just about any SPST switch without fear of overloading it with too much power. It also allows for enough power to illuminate the switch.
I am thinking you would just run the actuator + source to the grounded switch, then run another wire from the switch to the actuator + relay entry? DING!
The relay helps keep the power load from overloading the switch, as well as the tapped power source. Both of which scenarios can cause fires, and failure. Inline fuse will only keep from overloading the circuit, but a 10amp switch will fail with 20amps of power.
And, lol I am full of questions on this subject.. If you do run the relay through a switch, wouldn't the switch still be getting the entire 12V flow (is that dangerous). I know you said the actuator input wouldn't use as much power.. Yes, it still gets the 12v. It's not the volts that are the problem, it's the amperage draw. That pin on the relay draws very little amperage.
Hope this helps a bit.
__________________
Old 01-27-2007, 07:23 AM
My Garage
awesome, thanks for the clarification. I guess I should invest in a few relays to be on the safe side.
__________________
American cars
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
