What wires do I need for my system?
Old Dec 3, 2006 | 09:52 PM
dukat03's Avatar
Default RE: What wires do I need for my system?
Ahh you made me think on that one pad one
2 feet ????? negative ghost Ryder
MECP evan says the fuse should be 12 to 18 inches from the post i suggested 12 inches because of the civics small battery
you can go to MECP.com to verify it
ORIGINAL: ef4life
the fuse should be 1-2 feet from positive battery terminal, you made a mistake in your post. but very detailed and you know what your talking about.
Old Dec 3, 2006 | 09:55 PM
dukat03's Avatar
any of them will do just fine just depends on how much money you want to spend but the same for his amp will do for yours
Old Dec 3, 2006 | 10:00 PM
ef4life's Avatar
dukat03 in your first post you said the fuse should be 12 feet away, i was simply stating you made a mistake and should be no more than 1-2 feet away.
Old Dec 3, 2006 | 10:02 PM
dewmaster07's Avatar
haha, ya, ya did saw 12 ft. but i didn't even notice that until you pointed it out. I think it' spritty safe to say he ment inches.
Old Dec 3, 2006 | 10:08 PM
So... do you think you might be able to help me out with the doors? Cuase that would be awsome.
Old Dec 3, 2006 | 10:37 PM
dukat03's Avatar
Hahaha yea i did, dang OK it was late and a long post but good looking out
ORIGINAL: ef4life
Old Dec 3, 2006 | 10:41 PM
dukat03's Avatar
hope this works for you
[IMG]local://upfiles/16447/246484C3D8054458ACE4381D41AC3B2C.gif[/IMG]
[IMG]local://upfiles/16447/52BE1FDA5AA8405795BDCC5A0592F535.gif[/IMG]
[IMG]local://upfiles/16447/C2869F32822240A2BF4F7C142C61B033.gif[/IMG]
[IMG]local://upfiles/16447/18E9F523F3324D06BA3307B23E9F2D7A.gif[/IMG]
Old Dec 3, 2006 | 11:17 PM
dukat03's Avatar
IF YOU WANT TO PULL THE DOOR OFF PART
on some civics depending on month of the car , the speaker grill needs to be removed and the screws that are hidden are behind it
when you pull all the screws and wires snap the door panel apart from the door beging from bottom to top .
pull up on the door to release it from the window seal and its off
Old Dec 3, 2006 | 11:18 PM
Thanks, the Picture diagram helps a lot. When you say drill a hole for the tweeters "flush mount" what do you mean by that?
Old Dec 3, 2006 | 11:37 PM
dukat03's Avatar
FLUSHED AND NOT FLUSHED
[IMG]local://upfiles/16447/2622F9EBAE1843A0B3552ACEF4139F29.gif[/IMG]
[IMG]local://upfiles/16447/0AB846E40E664B8AACE53EEAC1FFD366.gif[/IMG]
