How-to: Embedding your picture in a post!
Login | |
How-to: Embedding your picture in a post! - 12/8/2006 12:51:02 PM
DevilsReject
The process of embedding your photos has advantages and disadvantages. The biggest advantage is you can show the larger file size pictures, and usually can see very good details that smaller pictures wont let you see. They can also allow for the higher quality pictures to be displayed for photo chopping and for editing. The disadvantages are actually quite obvious. The size of the pictures will cause you to have to scroll more, have to wait longer on the pictures to load depending on your internet connection, and may cause you to lag because of the amount of data coming from the picture. This is something we dont recommend doing very often, as it leads to the admin and mods to have to edit pictures or posts. For starters....you can help the process by resizing your pictures down to a more easier size to use. This can be done by using a photo resizing program such as Microsoft Office's Picture Manager, Microsoft Paint, Adobe Photoshop, Lview Pro, Paintshop Pro, and even some other programs as well. Need help resizing your pictures to make them fit? Here's a quick, easy way if you dont have any photo resizing programs.... 1) Go to www.resize2mail.com 2) Select option below (25% smaller 75%smaller etc..) 3) Click chose, and chose the correct image 4) Click ok 5) Right click on image after it is loaded and save as (desktop) Ok, so now we're ready to start...... First, you need to go and find a place to actually host the file. There are several places like www.imageshack.us www.photobucket.com and www.putfile.com These places will let you upload your pictures for free and host them so you can show them off anywhere you want just by pasting a web URL into a site. It's fairly easy. I chose to use Photobucket for this as I found it easier to use for demonstration purposes, and because it's easier to access from anywhere. To start, you need to create an account if you dont already have a hosting site account. To do this....go to www.photobucket.com Once there, you will need to register for an account. This takes a few seconds and you fill out a little information. Thumbnail Image
Once this is done, you should then login and you will get this screen... Thumbnail Image
From here, click Browse, and you will get a window that pops up...letting you search for your picture/file...Once you have found your picture, highlight it and click open. Thumbnail Image
You will then get a window that shows your file name and there will be a button marked UPLOAD. Click this. Thumbnail Image
The page will refresh, and you will see the file you uploaded. Beneath your picture will show a couple boxes with text in it. Thumbnail Image
The first box, says URL next to it. Highlight this text and copy it....we'll then be able to move on to the next step which is actually getting it to appear in your forum posts. Thumbnail Image
Log into the forum like you normally would and open a new post or reply to a post. Once there, you will be able to either click the IMAGE tab or simply type in [image][/image] or [img][/img] These are called tags and these are how your file will show up in the post. Thumbnail Image
Next, you need to paste that URL from the hosting site in between the first image bracket and before the second one. See picture below for example. Thumbnail Image
Once you've done this, go ahead and type in whatever info you want into your post and click the OK button. Your post should look like this now.... Thumbnail Image
Congrats on embedding your picture! If you think this is too complicated or just dont want to do this, try this way of posting a picture How-to: Post your picture in a post
_____________________________
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Civic Prices
Honda Civic
Civic Si Concept
Advertising Info
Contact Us |
Advertising |
Automotive Resources |
Honda Civic Links |
Archive |
About |
Legal |
Privacy Policy |
© Honda Civic Forum
