RE: PLS HELP! How do I remove cd player/radio & front speakrs from 02 civic sedan
first remove the pannel under the stering collum on the dash thenyou need to remove the pannel that the cigerete lighter is mounted in. Then if you look up at the bottome of the sterieo from where the cigrette lighter pannel was you will see that the sterieo is mounted in a bracket with the heater controls. there is four hex bolts with a philips screwdriver slot in theme that need to be removed. then you need to find any way possible to get your hand in behind that bracket to remove all the wires pluged in for the heater controls. once they are disconnected then you should be able to slide the whole unit out. sterieo, heater controls and all. then on the sides of the deck you will see the screws holding it to the bracket.
Its a pain in the a#% but look at it this way... If someone steals it, They earned it!
__________________
Go Fast Or Die Tryin
1999 Civic SiR
AEM Cold intake
Taylor Wires
17 inch Falkin Rims
Kumo Ecsta supra 712 Tires
Skunk 2 springs
shunk 2 camber kit
AGX KYB gas shocks
strut bars
Skunk 2 Short shift
