Go Back   HondaCivicForum.com > Your Ride > Engine & Internal > Swap Meet > ED-EF Swaps
Reply
Old 12-14-2006, 02:01 AM
97civic707 97civic707 is offline
My Garage
Default what swap for a 91 si
i was wanting to do an engine swap for my 91 si but i need it to pass smog cuz i live in cali. what would be the best swap for around 1500. i could get a b16 1st gen complete swap for 800 but it wont smog in cali. or should i just rebuild my d16 and turbo?
Sponsored Links
Old 01-09-2007, 01:20 PM
Powermidget Powermidget is offline
My Garage
Send a message via AIM to Powermidget
Default RE: what swap for a 91 si
drop a vtec head on there and go turbo...or find someone that can hook u up on the smog and do that dohc swap...if you get a motor newer than your car in caliand have all the docs you can have a ref check out your car certify it badge itand be legal for smogwith the dohc swap...its a process thats not particularly cheap but it makes the swap legit
__________________
86 Bronco XLT ~ Blown Tranny&Motor(Ebay'd to Texas)
91 CRX Si ~ Totaled
90 CRX Dx(b16) ~ Jacked
96 LS Teg ~ Traded
91 HB B18a1~Blown Trans FOR SALE
93 Miata MX-5 56000 orig miles SWEET!!!
Old 01-09-2007, 02:14 PM
Dommers Dommers is offline
My Garage
I have a 90 civic sedan dx 1.5lt lookin to put in a vtec i hear that you can just change the head and the Ecu can you help me i am srry this has nuttin to do with your question but i don't now how to post my own maybe you can help me with that also thank you
Dominic
Old 01-09-2007, 07:40 PM
My Garage
A head and ecu is all you should need (some new head studs wouldn't be a bad idea either oh and a hondata head gasket)...i believe the y8 head will fit your car but you should search the forum for more info...Its the head off the 93 and up civics you want to look for....i would also recommend looking into an oil line for your head to keep it lubed...ive dont have to much experience with the sohc vtec conversion but if you use the search fnc someone on here does....
__________________
91 CRX Si ~ Totaled
96 LS Teg ~ Traded
Old 01-10-2007, 12:09 AM
finalimpact finalimpact is offline
My Garage
Send a message via AIM to finalimpact Send a message via Yahoo to finalimpact
having the ecu with the swap would be nice.......but that would require an obd1 conversion as well as a mpfi conversion. these 2 conversion would net you the best gains. however the mpfi conversion would net you an even better gain than the vtec headswap alone while running dpfi.
__________________
Old 01-11-2007, 12:43 PM
My Garage
i thought the si was a mpfi.
Old 01-11-2007, 09:29 PM
My Garage
Quote:
ORIGINAL: 97civic707
your right..........i would blame my miss reading on being drunk but that was not a drunken post. so therefore it was my miss reading that made me look like an idiot[8D]
so an obd1 conversion or...........use a pr3 ecu, have it chipped with a sohc vtec map and have the knock sensor option disabled.
__________________
Old 01-20-2007, 10:25 PM
JLguy JLguy is offline
My Garage
Send a message via AIM to JLguy
i have the whole setup for you in my garage. resealed b18 with reworked pistons, dc header, Tanabe stainless 3" exhaust, integra LS trans AND ECU. motor has a total of 98 grand on it and it was resealed with the pistons worked about 15,000 ago. all that for 2100 negotiable. Lemme know man!
__________________
If knowledge is dangerous, where is the man that has so much knowledge as to be out of danger?
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
