Go Back   HondaCivicForum.com > Your Ride > Audio/Visual Electronics
Reply
Old 12-17-2006, 12:17 PM
ian125 ian125 is offline
My Garage
Default Wiring an amp question
Ive got the Infinty basslink arriving on tuesday. its a 97EX and i just wanted to know how to remove the gray side step panel things to put the wires underneath it.
oh, also wheres the best place to ground it at?
thanks
Sponsored Links
Old 12-17-2006, 11:20 PM
classiccarsrule85 classiccarsrule85 is offline
My Garage
Default RE: Wiring an amp question
Well your first question I have no idea since i have never owned anything newer than '93 but id have to say its held in by either screws or pop-able clips....
And to your second question depending on where you decide to put the amp you could either attach it to a preexhisting ground, attach it to a bolt that holds the seats or something attach to the body of the car but make sure you sand off the paint first to get a good ground...or you can go the extra effort and drill a hole somewheres in the trunk area and make it so a bolt will tighten down to it and sand the paint around that area where the ground will be touching and bolt'er down....
__________________
1995 Cx project car but Daily Driver
1994 Si project car in the works
Old 12-17-2006, 11:21 PM
dukat03 dukat03 is offline
My Garage
2 door or 4 door
2 door --- instructions
*1 remove your kick panel , there's a plastic tap in the middle remove it
2* remove the cap that's on your lock / unlock key insert where your trunk release is , there is a philip screw there
3* remove your B pillar (( that's the middle pillar )) ====pic below====
4* when removing the running board make sure that you look out for the trunk release it will start to catch on the panel when removing it .
5* you don't need to remove the back seat or the back pillar start to tug the wire around the seat towards the rear
when grounding the basslink don't ground in place of a stock screw ( example where the set belt bolt is ) make your own ground . the best place is right where your driver side rear straight tower is below that , just scrape off the paint and ground there {{{{{ make sure you don't use a long screw your gas tank lines are near there , use a half inch screw , a metal screw you can get 10 for a 1$ at your auto parts store }}}}}
4 door --- instructions
same as above you just have one more panel to remove which is the rear running board
[IMG]local://upfiles/16447/224EA77C231C4001BEC201863A19C2E1.jpg[/IMG]
[IMG]local://upfiles/16447/EBE6B6E7F2434D6784B80E6062C1B9C7.jpg[/IMG]
Old 12-18-2006, 08:12 PM
My Garage
Hmm thanks guys. I kinda got a general understanding of what im doing now.
Welp, gonna try and install it tommorow when it arrives. Ill let ya know how i do..
thanks
Old 12-18-2006, 08:43 PM
windcalmer windcalmer is offline
My Garage
Where are you mounting the amp?
__________________
Quote:
I know my environmental footprint is massive because I drive like and asshole!
Old 12-18-2006, 08:45 PM
My Garage
I havent decided yet. The infinity basslink has the amp inside it. so wherever i can get the best sound. What's the ideal place for it?
Old 12-18-2006, 09:27 PM
Method Method is offline
My Garage
in your trunk.
__________________
Quote:
ORIGINAL: Try.Fail.Repeat
Haha I have a vagina. But thanks for the sentiment.
Old 12-18-2006, 09:36 PM
My Garage
DURRRR!
but like, right behind the rear seats? off to the side?? or will i just have to play around with it till i find the rite spot?
also, is it safe to drill anywhere in the trunk?
thanks
Old 12-18-2006, 09:43 PM
2slo4u 2slo4u is offline
My Garage
what are you drilling for?
Old 12-18-2006, 10:01 PM
My Garage
so i can screw the mounting legs in.
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
