Go Back   HondaCivicForum.com > Your Ride > Engine & Internal > Swap Meet > ED-EF Swaps
Reply
Old 12-18-2006, 01:52 PM
97civic707 97civic707 is offline
Default zc in a 91 si q's
i have a 91 si. i was thinking of doing a zc swap or just doing a mini me. what would be best. with a zc would the engine bolt up to all my parts like tranny and everything els. also would it smog in cali. what would make more power a dohc zc or the mini me. thanks for the help
Sponsored Links
Old 12-20-2006, 08:49 PM
finalimpact finalimpact is offline
Send a message via AIM to finalimpact Send a message via Yahoo to finalimpact
Default RE: zc in a 91 si q's
couldnt say much for smog but id say either the mini me or dohc zc would work great. id say they would both be close in power. but if your intentions are to use forced induction later down the line i would choose the dohc zc for the ability to tune overlap.
__________________
Old 01-09-2007, 12:08 PM
Powermidget Powermidget is offline
Send a message via AIM to Powermidget
The mini me swap will be easier to pass in cali cause you maintain the stock long block...you will def get some more power out of the zc but being from cali i can tell you there will be some smog issues not necessarily emissons but on the visual inspection
__________________
86 Bronco XLT ~ Blown Tranny&Motor(Ebay'd to Texas)
91 CRX Si ~ Totaled
90 CRX Dx(b16) ~ Jacked
96 LS Teg ~ Traded
91 HB B18a1~Blown Trans FOR SALE
93 Miata MX-5 56000 orig miles SWEET!!!
Old 01-15-2007, 12:22 PM
SIred91 SIred91 is offline
Send a message via Yahoo to SIred91
They will both yield the same power, the zc(if dohc) will have a little more torque, I went with the sohc zc and I love it, its a lot peppier up top than my A6 was, and the compression is still quite low, so it will love some boost as soon as my edelbrock kit is installed...
I personally would stay away from the dohc zc for the only reason that internal parts are difficult to source, other than that, everything bolts right up!
__________________
The Mind Is A Terrible Thing To Taste, But A Wonderful Thing To Waste!
91-CRXsi zc
91-lude 4WSsi
If you mod 2 or 4 strokes then I can hook you up!
StealthRacingTech.com
Old 01-15-2007, 04:00 PM
Babyboy05 Babyboy05 is offline
are you planning on stayin obd0?? If your gonnastay obd0 then stick with the dohc zc and if your gonna do the obd1 conversion then go with a d16z6! I have one in my crx and it pulls great!
Old 01-15-2007, 04:03 PM
oh yea and yes the dohc zc bolts right up with d-series tranny and all...most all d-series parts line up..
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
