Go Back   HondaCivicForum.com > Your Ride > Engine & Internal > Swap Meet > ED-EF Swaps
Reply
Old 12-22-2006, 07:35 PM
vtiman vtiman is offline
Default Help required regarding gearbox
Hi,
Hope you can help. I am from the UK and my younger brother has just messed up his gearbox.
The car will not work in 2nd gear or reverse but works in the rest of the gears.
His civic is a 1994 1.6 vti vtec eg6 engine-b16a.
He has been offered a gearbox from a 1.6 vti ef9 engine-b16a 1988-1991.
Will it work? can we use the gearbox from the older engine in the one he has? I have been told that the gear ratio's are different and the mounts may also be different. Can anyone direct us on the right path please?
Apologies if this is int he wrong section but need urgent feedback.
Thanks again for yur time.
Sponsored Links
Old 12-22-2006, 10:55 PM
sacicons sacicons is offline
Default RE: Help required regarding gearbox
no. the mounts and gears are fine, but the clutch on his car is hydraulic, and the one on the older trans is cable-actuated, so you have to buy a somewhat expensive conversion adapter to make it work. hes better off getting the correct transmission.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 12-23-2006, 04:54 AM
Thanks for help mate.
Will locate a 92+ gearbox due to the differences in the clutch.
Thanks again.
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
