RE: 6 x 9 installation troble
pop the trunk look under the speakers and there should be 3 or 4 10mm or 8mm bolts around the speakers ( theses are basically holding the grill on ) take them off and the grill will come off from the top then remove screws holding the speaker in
if you don't have this set up then your rear dash panel has to be removed starting from the seats folding down , the c pillars being pulled and then the back dash
i can get you a diagram is it a 2 or 4 door
