We're adding and testing new features:  Create your Garage, used it? Give us some feedback here.
Go Back   HondaCivicForum.com > Your Ride > Nitrous, Super Chargers, & Turbos
Reply
Old 01-04-2007, 01:10 PM
stefo stefo is offline
My Garage
Default would a 91 dx hatch be worth turboing?
im looking at a 91 hatch right now and i was wondering if it would be worth turboing ... its a dx d15b2 engine has 92 hp lol.. would it be worth turboing? and what else would i need to turbo it like every part i need to replace and which parts would i need to buy? im jw the engine has 240 000 miles on it... and engine has no leaks... does no smoke.. btw
__________________
Sponsored Links
Old 01-04-2007, 02:39 PM
aryiman98civic aryiman98civic is offline
My Garage
Send a message via AIM to aryiman98civic
Default RE: would a 91 dx hatch be worth turboing?
ok first and foremost you will have to do a compression test on your engine to see if your internals are good or not. to do this you can go to autozone and rent a kit and take it home and do your own testing. next you need to look at this list that pete made: http://www.hondacivicforum.com/m_196090/tm.htm
here is another link that will be helpful that tells you all about each part and what it does, after you know your engine is healthy then you can start researching on turbos.
http://www.beesandgoats.com/boostfaq/g2icturbo.html
__________________
spooling on the b16!
Old 01-04-2007, 11:33 PM
riceburner700's Avatar
riceburner700 riceburner700 is offline
My Garage
Send a message via AIM to riceburner700
i wouldnt do it with that many miles, if you are buying this car as a second just build a motor for it. but if the compression is good then go for it
__________________
cylinder head guru!
Non Vtec power
Old 01-05-2007, 12:13 PM
My Garage
what would you say is a decent compression to have?? and if its too low what are some simply ways to get the compression back on... injectors? new seals? etc...
__________________
Old 01-05-2007, 01:32 PM
Forty04 Forty04 is offline
Administrator
My Garage
A compression test is used to see if all your cylinders are working at the same (or near same) efficiency. If one cylinder's compression is way lower than the rest, that "usually" means your rings are going out (there are many other things that can cause it too, but rings seem to be the ones I hear about most). If this is the case, then that cylinder will probably take a dump on you almost instantly when you boost, depending on the severity of damage.
If yo udon't know how to run a compression test you can either search, or I can give you a run quick run down. It's free to rent the tester from autozone, and takes about an hour (max) in the driveway/garage.
There are no "simple" ways to up the compression in a cylinder, if your motor is bad, you'll more than likely have to rebuild the bottom end, or swap it
__________________
Don't PM me with tech questions
Antartic Blue Super Sports wagon with C.B. and optional Rally Fun Pack
Old 01-05-2007, 07:55 PM
My Garage
oh :-( **** lol imma read more into it... thanks to all of you
__________________
Old 01-06-2007, 10:34 AM
Administrator
My Garage
Quote:
ORIGINAL: stefo
Thats the best thing you can do. When I first started getting into the whole boost thing, I thought that I knew pretty much everything there was to know, not the case. The more you dig into the project, the more you learn how little knowledge you really had. My one regret is that I didnt read even more into before starting, but, can't complain now
__________________
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
