We're adding and testing new features:  Create your Garage, used it? Give us some feedback here.
Go Back   HondaCivicForum.com > Your Ride > Engine & Internal > Swap Meet > EK Swaps
Reply
Old 01-06-2007, 06:57 PM
Erich73 Erich73 is offline
My Garage
Default 97 Civic EX b18c swap
I just purchased a B18cmotor with LSD tranny to drop into my 97 Civic EX. i have4 questions for the vets on the board.
1. Motor mounts. what motor mounts will i need to complete this swap. Ive read the rear tranny mount from 99-00 SI, and the Del Sol DOHC A/C bracket (i want to keep my A/C).
2. Radiator hoses. What do i need to reconnect the radiater hoses from my stock radiator to my B18C motor?
3. Wiring. What other wiring will i need to do? my swap came with the P72 ECU and complete harness.
4. the motor i purchased is an OBD1. what other parts will be needed to drop this into my OBD2 car?
Thanks in advance.
-Erich
Sponsored Links
Old 01-07-2007, 11:19 AM
96civic285whp 96civic285whp is offline
My Garage
Default RE: 97 Civic EX b18c swap
#1 Is correct that's all you will need. When I did mine I used my a/c compressor from my 96 EX,and the del sol bracket and only two bolts lines up. I did'nt have the compressor from the GSR so I tried to make what i had work. It took a year before the bolt broke and the compressor fell off.
#2 I can't remember what i did for hoses I think I made the stock GSR hoses work
#3 This goes along with #4. You will need a OBD1 to OBD2 adapter. It'll cost about $70 and it just plugs from your harness to your computer. You will also need to combine your stock 97 EX wiring harness with your GSR wiring harness. I paid a local shop to do mine for 100 bucks and make it plug and play. They even labeled everything for me.
#4 Just keep in mind that OBD1 has less emissions regulators on them so this swap will be illegal in some states. You will not pass any emisssions testing.
I hope this helps and good luck with your project!
__________________
Old 01-07-2007, 11:26 PM
My Garage
thanks for the info!
i found this site that seems to have these 3 brackets...
www.hondaautomotiveparts.com
engine mount part #18333 $46.94
rear bracket part #23225 $40.46
CRV A/C bracket part#31252 $64.88
all together im looking at$171.10 shipped. some guy on ebay wants $115.00 for just the A/C bracket!
is there any other mount i need?
i just found out that the motor i purchased is an OBD2 motor. this should make things a little easier for me.
Old 01-08-2007, 08:11 PM
My Garage
Ive been reading in some forums that the GSR header will be a few inches too short to reach my cat since the GSR cat is longer. i would like to buy the DC 4-1 headers, i am also adding an Apexi cat back set up.
is there a bracket i can buy to bolt on while im installing everything or will i need to bring my car to an exhaust shop so they can fabricate the extension?
if i buy the gsr cat, will this fit/resolve my issue?
one of the sellers on ebay, ssautochrome, is selling a jun style 4-1 header witha 4"extension included...
Ebay auction150077496512
is this crap?
Old 01-08-2007, 08:22 PM
sacicons sacicons is offline
My Garage
Quote:
ORIGINAL: Erich73
is this crap?
yeah, its crap. and in my case, 4" would have been too long anyway. i made my own extension, and it ended up being just about 2" long. though i only had that problem with the DC header. i fit the Thunder header from West Imports (forum sponsor) on and it fits perfectly, so i think the dc header might be for an ls.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 01-23-2007, 07:09 PM
My Garage
if i buy a new motor mount kit (ie. Hasport) will i still need these 2 brackets...
Old 02-04-2007, 07:36 PM
djmikemendoza djmikemendoza is offline
My Garage
Send a message via AIM to djmikemendoza Send a message via Yahoo to djmikemendoza
A 2 piece header or 1 piece? for this swap?
Old 02-05-2007, 02:55 PM
My Garage
1 piece
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
