Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
Sov's Build FINISHED 5/19 (pics pg 14)
  Printable Version
Honda Civic Forum >> General Automotive >> HCF Project Section >> Sov's Build FINISHED 5/19 (pics pg 14) Page: [1] 2 3 4 5   next >   >>
Login
Message << Older Topic   Newer Topic >>
Sov's Build FINISHED 5/19 (pics pg 14) - 1/9/2007 12:45:25 AM
SovXietday
Status: offline
SovXietday's photo gallery
Here you go Johnny, haha.
Alrighty, well this will be my build progress etc. Currently I have a stock D16Y8 making 210whp and 167wtq on just 7psi of boost. She's pretty quick, I am waiting for the tracks to reopen so I can shoot for a mid to low 13 before I swap to my new build. Ok, enough about what I have, let's move on to what my goals are.
Goals.
300whp+ Pump Gas (93 octane)
400whp+ Race Gas (100 octane)
11.5 Quarter Mile
130mph Trap Speed
Engine build is as follows. I will be sticking with the SOHC engine, the OBD1 D16Z6 is going to be my power plant. Oh, I payed $50 for the entire engine with intake mani and throttle body. So, as follows:
D16Z6 OBD1 1.6L SOHC VTEC
Entire Engine
Block :
Vitara 75mm pistons
Eagle Forged H-beam Rods
New OEM rod bearings
New OEM Water pump
New OEM Oil Pump
New Oil pan as the one that came on the engine is garbage.
Head :
Keeping stock ports
Zex 59300 cam
I'm not sure what springs I'm going with, the car will be revved to 8000-8200 so any recommendations would be cool.
Stock HG
As you can see, this is a very very simple build. I don't believe there's any reason to go overly crazy with these engines.
Transmission :
New bearings
OBX LSD
Stock 1st Gear (nothing longer)
1.762 2nd Gear (longer than stock EX)
Stock 3rd Gear
1.033 4th Gear (shifting at 8200 RPMs I will hit the limiter at 132mph on 24" slicks)
.771 5th Gear (slightly shorter than current)
Either Action 2MD or Competition Stage 5 clutch
LSDmotorsports 11lb steel flywheel
The idea is to try to maximize the power output for those crucial 60's, and then the gearbox tightens up through 2-3-4 in order to stay in boost through the shifts.
Turbo and Fuel Setup
The overall turbo setup will only change slightly. I purchased a ramhorn style manifold to aid in top end flow in order to reach my goals. Setup will be as follows:
T3T04e (T3/T4) 57trim .63A/R and Stage 3 wheel.
CC-fab Ramhorn Manifold
38mm Tial Wastegate
3" Downpipe and full catback exhaust (may add an ecutout, we'll see)
2" Dumptube (may route it out of the bumper, fireball FTW!)
Upgrading to 2.5" IC piping if the current doesn't work out.
PWR intercooler 32x12x3
Greddy RS BOV
Fast Turbo Oil lines
Custom Catchcan setup
Apexi AVCR EBC
Fuel/Tuning :
Precision 780cc Injectors
Walbro 255lhp fuel pump
GM 3bar map sensor
P05 Chipped with Crome
Will be tuned by yours truly
Pictures as parts come in of course. I'll have to get pics of the stripped engine at my dad's work next time I'm down there etc. I'm hoping for the build to be done and running by Spring, so I've got some time to get my stuff together.
Pics as they come.
New gears. Far left, the 5th gear with main shaft, top middle is the 2nd gear, far right is the 4th gear.
All the tranny parts.
The head, little dirty but in good condition.
Mmmm. More goodies. Eagle rods, CCfab ramhorn, ARP head studs.
I love this thing, haha.
Fun truly does come in a box... or in this case a set of boxes haha.
Vitara 75mm pistons
Precision 780cc injectors, unsaturated
Zex/Comp 59300 camshaft
Action 2MD Clutch
< Message edited by SovXietday -- 5/20/2007 7:59:52 AM >
_____________________________
Champ White 1996 Civic Hatchback - 57trim SOHC
Black 1998 Z28 Camaro - LS1 M6
Post #: 1
RE: Sov's Build - 1/9/2007 4:46:42 AM
Honda_man
Status: offline
sounds freakin sweet man. keep us posted as much as possible, with lots of pics... this sounds like its gonna be a toast to what the little d can really do, on a budget.
f/s-85 Ford Bronco
-lifted, 31" tires, grill, push bar
-351 W, 117 K, black
-90 Dodge Dakota
-30" tires, grill gaurd, roll bar
-180 K, white
BOTH RUN GREAT, AUTO W/ PWR WIN/LOCK, SOME RUST
Want-02-up Si Hatch, low miles
(in reply to SovXietday)
Post #: 2
RE: Sov's Build - 1/9/2007 7:37:57 AM
Forty04
Status: offline
Forty04's photo gallery
Sounds like a real nice build Sov, simple, yet very well thought out and efficient.  Any particular reason why you're sticking with the stock port?  And, have you given any thought to running something other than stock for your axles?  With that setup I foresee you snapping an axle with every pass down the 1320
Best of luck to you throughout the build.  After seeing your setup as it is now, I have full confidence that the next setup will be equally clean and even more bad ass.  Keep us up to date, with lots of pics
< Message edited by Forty04 -- 1/9/2007 7:39:19 AM >
Don''''t PM me with tech questions
Antartic Blue Super Sports wagon with C.B. and optional Rally Fun Pack
(in reply to Honda_man)
Post #: 3
RE: Sov's Build - 1/9/2007 7:41:04 AM
Talon585
Status: offline
Wow man looks like you have everything figured out already.  Like everyone says we need constant updates and pics or we shall sic the dogs on ye
Ain't got no quarrels with God, Ain't got no time to grow old
(in reply to Forty04)
Post #: 4
RE: Sov's Build - 1/9/2007 11:20:08 AM
POLYTHING
Status: offline
POLYTHING's photo gallery
WTB: 2000 SI INTAKE tube. OEM or aftermarket WELCOMED!
(in reply to Talon585)
Post #: 5
RE: Sov's Build - 1/9/2007 12:54:36 PM
mill$civic
Status: offline
mill$civic's photo gallery
Sounds great. What alot of work..keep us posted with the build.
Member since Feb 2005
(in reply to POLYTHING)
Post #: 6
RE: Sov's Build - 1/9/2007 6:17:34 PM
cpl rampage
Status: offline
sweet, thats a sick sounding project, sounds like what i want to do, i will have to see what it turns out like
ARE YOU IN NEW ENGLAND, Check out the List, we want to have a meet!
http://www.hondacivicforum.com/m_418142/tm.htm
(in reply to mill$civic)
Post #: 7
RE: Sov's Build - 1/9/2007 7:04:18 PM
ef4life
Status: offline
ef4life's photo gallery
nice list man, and its a good mix of oem and aftermarket to build a relialbe powerful engine. props to you
(in reply to cpl rampage)
Post #: 8
RE: Sov's Build - 1/9/2007 7:20:13 PM
SovXietday
Status: offline
quote:
ORIGINAL: Forty04
Thanks for the comments guys, I'm really anticipating this build and all of my off time has been spent reading about what I want to do.
As for the stock ports, I'm building a D because I don't have a ton of money. Good port jobs are a lot of money, that and stock ports have been proven to make 450whp. As for axles, again, a lot of guys running 400whp run stock axles or Autozone remans. It's all about preloading.
Just got my first credit card... 9K limit. Oh how tempting it is.
Post #: 9
RE: Sov's Build - 1/9/2007 8:59:44 PM
riceburner700
Status: offline
riceburner700's photo gallery
9K HTF cosigned you on that. mines only 500 bucks because i have small amount of credit
non-vtec ALL THE WAY
cylinder head guru!
Post #: 10
Login OR Register now to post a reply to this forum topic.
Honda Civic >> General Automotive >> HCF Project Section
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414258
remmy11165
fiirkan10543
mill$civic8473
marty8273
mxs8006
fliphkd7207739
nail i3unny7705
sacicons7699
addiction2ba7489
New Vendors
K&N Engineering, Inc.
