Energy Suspension polyurethane boots
Login | |
Energy Suspension polyurethane boots - 1/9/2007 10:16:51 PM
rit14623
Brand: Energy Suspension Product: tie rod end, front end links, ball joint polyurethane boots Color: black Cost: $22 Time: A couple of hours but I had to change a steering rack boot which took a lot of time. You do need a tie rod puller tool to pop off the tie rod end and the ball joint ends and the front end link ends as a hammer is not a viable solution. Rental cost was $14. It's quite simple. Remove cotter pin, unbolt castle bolt, use tie rod puller tool to unconnent tie rod end, remove old boot, stare at it, throw it away, pick up new boot, add grease, put on the tie rod end, reconnect, bolt on castle bolt, insert cotter pin and lock it in. Do the same for the other parts. It does require muscle so pansies may be unable to reconnect the ball joint while trying to put the castle bolt back on. Ride: Steering has improved a smidge. That's about it.
Contact Us |
Advertising |
Automotive Resources |
Honda Civic Links |
Archive |
About |
Legal |
Privacy Policy |
© Honda Civic Forum
