Go Back   HondaCivicForum.com > Your Ride > Suspension, Brakes, Tires & Wheels
Reply
Old 01-10-2007, 05:37 PM
viciv viciv is offline
My Garage
Default HELP! cant get rear shock bolts out!
got the new Ksports on the front no problem but i CANNOT get the rear shock lower bolts to budge. itried heating them with a torch and hitting them with a BIG hammer but to no avail, theyre stuck, seem to be fused to the bushings. I am out of ideas short of removing the entire lower control arms and getting them pressed out or something.
any ideas?
Sponsored Links
Old 01-10-2007, 06:56 PM
mxs's Avatar
mxs mxs is offline
Administrator
My Garage
Default RE: HELP! cant get rear shock bolts out!
Quote:
ORIGINAL: viciv
that's what you have to do. you will most likely have to cut the bolts out. the new ones will run you about $8 each at the dealership. If the bolts are seized in the control arm bushings, you may need to have new bushings pressed into the LCAs.
__________________
Driving takes three abilities: Accelerating, braking, and turning. More power only helps acceleration. Lower weight helps all three.
PLEASE DON'T PM ME WITH TECH QUESTIONS, I WILL IGNORE YOU.
Old 01-10-2007, 08:36 PM
sacicons sacicons is offline
My Garage
try PB Blaster first. spray them down and wait 5 minutes, then spray them again and wait 10 minutes, then try getting them off. that stuff works wonders.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 01-10-2007, 08:40 PM
ej6buddy's Avatar
ej6buddy ej6buddy is offline
My Garage
i hope i don't have that happen to me when i install mine in a couple days.
__________________
Old 01-10-2007, 09:02 PM
My Garage
thanks.what is pb? i soaked em with wd40 and hit em HARD with a big ol hammer, nuthin doin.what a buzzkil.
BUT it already handles MUCH better w/ just the fronts on.
i think if i have to get new bushings i'll getksportarms, the onesthat come with new bushings for under 2 hundy.
Old 01-10-2007, 09:27 PM
mxs's Avatar
mxs mxs is offline
Administrator
My Garage
Quote:
ORIGINAL: ej6buddy
if your car has always been in the south you might not have a problem
__________________
Old 01-10-2007, 10:59 PM
ej6buddy's Avatar
My Garage
Quote:
ORIGINAL: mxs
Quote:
ORIGINAL: ej6buddy
yeah, it has been in the south, no rust anywhere here, i didn't think about that on his car
__________________
Old 01-10-2007, 11:05 PM
Street Sniper Street Sniper is offline
My Garage
have you tried putting the jack under there to relieve the weight off of them?
Wait... did I not understand the question?
__________________
Tuned by G-Tech... Powered by YooHoo.
Quote:
...there's more than one way to skin the horsepower cat.
Old 01-10-2007, 11:56 PM
My Garage
yeah i tried that too, those things arent going anywhere unless i press them out with a bearing press, i think. that is, if i can get the other lower arm bolts out. nightmare!
Old 01-10-2007, 11:58 PM
mxs's Avatar
mxs mxs is offline
Administrator
My Garage
it's pretty normal for a northern car that is 12 years old. just find someone with good tools to get them out.
__________________
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
