I've never really dealt with suspension mods at all other than a strut bar, so i'm kinda iffy as to if i should install my S-Techs myself. You can just do it with a jack right? Theres a local shop that will do it for me, and if they do it for me, how long does it usually take? So i guess i'm saying being an absolutely beginner with suspension, should i do this myself?
My local charges $150+ tax. At some point in everyone's life, they had never done it either. I say go for it and spend the $150 on another upgrade.
Here is a DIY I did on doing the rears. Look that over and see if it makes sense to you. The fronts are only slightly more complicated by a couple more bolts, but do-able. Even as a complete beginner you should be able to do all 4 in< 3 hours. If you run into problems, just come post back or Pm me.
do they salt the roads in your area?
__________________
Driving takes three abilities: Accelerating, braking, and turning. More power only helps acceleration. Lower weight helps all three.
PLEASE DON'T PM ME WITH TECH QUESTIONS, I WILL IGNORE YOU.
you're going to need air tools and/or help from a friend
__________________
in this pic flip its the part circled in yellow, if they do salt alot you will have a problem getting the lower control arm bolts out, if you do it your self try and use airtools and get some p-b blaster
Do it. A shop would charge about $50CAD a spring.So $200, plus the alignment afterward.
I have never done it eather but when (if) I get my coil-overs,I plan on doing it myself. There is some really good detailed DIYs on the net if you do some searching on different honda sites.
